Isobaric - less then
Old 2nd January 2012, 08:45 PM   #31
ODougbo is offline ODougbo  United States
Default typo
oh I've been busy.....check em out.
A pair of Fostex 125wks - aprox $120.
New sub box - aprox $40.
The sound is very, very nice.
Now I do need to rebuild the test sub box shown, I was going to go with the keystone shape, PR in the back.
This design has a 1.75db rise at 34hz, according to computer modeling. Now if there was a fellow that was wizard in WinISD, I'd sure like to know if I should go with a slightly bigger box. (existing box 1.16cf, tuned at 33hz)
Dayton 10" PR (not on sale now)
FS 20Hz
Vas 3.88
Qms 2.50
Cms .67 mm/N
Rms 4.89 kg/s
Sd 340 sq. cm
xmax 10mm
Old 2nd January 2012, 11:56 PM   #32
revboden is offline revboden  United States
revboden's Avatar
You really should learn Hornresp. Those little drivers work well in a small TH.
For the dayton 299-114
Old 3rd January 2012, 02:08 AM   #33
Don Hills is offline Don Hills  New Zealand
Originally Posted by revboden View Post
... or you could be using Middle english... are you in the 1300s, are rouges chasing you through a brush while you type? ...
rouges? Did you mean Redcoats? They were 17th century. Or did you mean ruddy complexioned rogues?
Old 3rd January 2012, 02:42 AM   #34
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
FS 20Hz
Vas 3.88
Qms 2.50
Cms .67 mm/N
Rms 4.89 kg/s
Sd 340 sq. cm
xmax 10mm
How sweet widdle baby onkens.
That's kind of the plan.
Yesser fer $5 they sure do. It don't take 80l neither.
@ Rev
Grammar Girl
Dan
Old 3rd January 2012, 09:12 AM   #35
I may change my nick to Renegade.
Rev, thanks for the advice and brighten up the thread with some nice colors.
I’m going to need more speakers……..
Old 3rd January 2012, 03:32 PM   #36
Originally Posted by NEO Dan View Post
Almost forgot...
Dan, I thought I would build the TH project next; the illustration is a little off, I think.
The 8” speaker baffle board would have to be “behind” the 9” outside board.
Also, was considering using Ύ” mdf for the 20” x 24-3/4” sides. The 9” boards would be need to be ½” wider.
Looks like fun, thanks.
Old 3rd January 2012, 06:49 PM   #37
NEO Dan's Avatar
Oh Dough,
You are a Doug right?
Really? Whatever keeps the OCD twitch at bay man.
If you think about it the sides are braced every 3"-7", so 1/2" material is more than adequate IMO. You could always build in ply, but no need really. I'd save the good stuff for something down the line once you get a handle on what you want from a TH.
If you get your handle changed it should be Verdana:
HTML Code:
[FONT=Verdana]Dan, I thought I would build the TH project next; the illustration is a little off, I think.  [/FONT]
[FONT=Verdana] [/FONT]
[FONT=Verdana]The 8” speaker baffle board would have to be “behind” the 9” outside board.[/FONT]
[FONT=Verdana]Also, was considering using Ύ” mdf for the 20” x 24-3/4” sides. The 9” boards would be need to be ½” wider.[/FONT]
[FONT=Verdana]Looks like fun, thanks.[/FONT]
Dan
Old 3rd January 2012, 07:56 PM   #38
Yes, Doug. Sorry about the code, some glitch in the compter :-/
Thanks for the reply.....I'm on it.
Old 3rd January 2012, 08:06 PM   #39
fhperez is offline fhperez  United States
Send a message via AIM to fhperez Send a message via MSN to fhperez Send a message via Yahoo to fhperez Isobaric - less then
I Just bought 4 of these because of this thread, I would love to see someone design a TH for these, I saw the pictures posted of one using 2 of these, but maybe we can designate a thread for this on its own... The only TH I have built is JBells ss15, I have 4 of them, I would love to make some of these for smaller home parties.
The best DJ in Houston using the SS15 born in diyAudio from Jbell and the rest of the community!!
Old 3rd January 2012, 08:17 PM   #40
NEO Dan's Avatar
No problem, this post is fine
1-40Hz dual driver TH at full output with these drivers is roughly what you get out of a SS15 with a few watts. Why not build the jbell bass sticks with the 55-2421 for a small rig?
Dan
Isobaric - less then Hide this!Advertise here!
20 Hz to 20 kHz Dipole Speaker System MJK Full Range 69 29th September 2008 01:37 PM
Power Amp Toroids 20-0-20 VAC 500 VA daedalus Swap Meet 17 24th May 2006 07:30 PM
Mullard 5-20/Maplin 4-20 modification to NON-Ultra Linear mode???? vinyvamos Tubes / Valves 1 28th January 2006 04:07 PM
