Isobaric - less then
Old 10th January 2012, 09:51 AM   #111
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
  • Looking at bjorno's work it looks like the stuffing will alter response below 40Hz for a leaner response.
  • I would use the dowels between the free ends of B3&B4
  • Very lightly fill the line from the throat down to at least the bottom corner below near S4/B3
  • I don't think you need to remove the drivers.
  • I'd go in through S4
Dan
Old 10th January 2012, 10:33 AM   #112
ODougbo is offline ODougbo  United States
Like this?
Old 10th January 2012, 03:19 PM   #113
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Originally Posted by NEO Dan View Post
MCM Part #: 50-6268 should work with the 299-114 setup, though it won't fit in the box.
Too bad the MCA2550E is NLA.
Is MCA2550E discontinued, or out of stock?
PE shows it due in on 2/9/2012.
Old 10th January 2012, 03:45 PM   #114
tb46 is offline tb46  United States
Hi ODougbo,
More like the attached side view. Also, from bjorno Post #105: "...Stuff evenly to half-ways of L counted from the S1 area: Total Amount of Stuffing = 0.461 lb = 0.209 kg."
Oliver
Old 10th January 2012, 03:59 PM   #115
Okay Oliver, crystal clear now.
Sorry about the basic TH 101 questions, this is all very new and trying to catch up.
Cool Graphic!
Thank you, Doug
Old 10th January 2012, 04:01 PM   #116
The PE High/Low level amp might not have the aggressive bass rolloff.
Old 10th January 2012, 04:28 PM   #117
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by tb46 View Post
Hi ODougbo,
Hi Oliver,
I tested with progressive Stuffing too but kept the weight of the Stuffing as earlier = 0.461 lb = 0.209 kg:
b
Old 10th January 2012, 04:36 PM   #118
Hi bjorno,
"...I tested with progressive Stuffing too but kept the weight of the Stuffing as earlier = 0.461 lb = 0.209 kg."
Neat!
Oliver
Old 10th January 2012, 04:44 PM   #119
Hi Odougbo,
"...this is all very new and trying to catch up..."
That's why we're here, just trying to learn. By the way, when building speakers of this style with stuffing it is always good practice to leave one side plate removable until at least the initial experimenting is over. Naturally, that can get you into trouble with air leaks. So you need a good seal between the dividers and the removable side panel.
Oliver
Old 10th January 2012, 05:32 PM   #120
TheGimp's Avatar
Can one use weather stripping to help seal the side that is removable, or does it cause other problems?
Isobaric - less then Hide this!Advertise here!
20 Hz to 20 kHz Dipole Speaker System MJK Full Range 69 29th September 2008 02:37 PM
Power Amp Toroids 20-0-20 VAC 500 VA daedalus Swap Meet 17 24th May 2006 08:30 PM
Mullard 5-20/Maplin 4-20 modification to NON-Ultra Linear mode???? vinyvamos Tubes / Valves 1 28th January 2006 05:07 PM
