Hello.
I'm lost for ideas of what to do with my 8 PD 12" woofers. I'm considering selling them, but will probably not get much for them. Therefore I wonder if they could play a more reasonable role in a second soundsystem. (They don't fit in my main system, since it already consists of dual JBL-2226 midwoofers/side - simply too smallish I do want a second system coupled to the TV, and I have a miniDSP 2-ch. aktive crossover to feed the loudspeakersystem. Let's say I could build something for the 8 PDs from 80-120Hz, and down. (Or pehaps I could build something fancy, and get a better sale for a complete system, than for the individual drivers?) My problem is that I'm not used to sim/manipulate such high EBP-drivers. What options do I have if I want SQ down to at least 30Hz? Preferably not crazy big enclosures. Precision Devices International Limited Fs 50.238 Hz L1 0.999 mH L2 1.773 mH Res 87.286 Ohms RMSE-load 0.905 Ohms Qts 0.297 RMSE-free 1.718 Ohms Qms 5.024 Vas 58.945 Litres Qes 0.316 Mms 67.410 grams Sd 530.93 sq cm Cms 148.887 µM/N R2 8.105 Ohms BL 19.228T/m Xmax 7.00 mm Re 5.493 Ohms My initial idea is to build 2 separate enclusures with 4 woofers. 2 woofers facing forward, and 2 woofers facing backwards. Sealed and push/pull-coupled pairs. 2 ohms imp, but I think Hypex or proamps could do the job. EQed to desired response. What do you think about that idea? Thanks.
Putting out fire with gasoline. Last edited by Rojoh; 23rd December 2011 at 06:41 PM. |
#2 |
Four tapped horns?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#3 |
Specs (apart perhaps from the high Vas) look good for 30 Hz THs.
A quick sim suggests that, if you can live with 6 cu.ft. sub boxes per sub, you could use four of them in 30 Hz THs, and the other four as midbass drivers in two/way tops.
www.diysubwoofers.org |
#4 |
it is designed around a 12 incher.
sorry, I haven't found the link yet! Merry Christmas! Ben |
#5 | |
isobaric 'clamshell' 2 woofers each box with 8 woofers you have enough to build 4 'subs' with EQ they would do fine as high power subs or you could build 2 subs with double isobaric clamshell mounting that might be something really special btw, series/paralel combination would give you a better 5ohm load |
#6 |
Holy crap! Yall are crazy!
#8 | |
#9 |
regards, Ben
#10 |
They seem to model fine as bjorno's T-TQWT, maybe 4 duals @ about 110 L_net each.
Oliver |
| Precision Devices woofer for hifi? | Boscoe | Multi-Way | 4 | 13th December 2010 05:18 PM |
| Precision Devices PD.8BM20 | inrank | Multi-Way | 4 | 21st July 2010 07:53 AM |
| Precision devices...... | Village Plank | Multi-Way | 10 | 14th December 2008 07:49 PM |
| Precision Devices | tinitus | Multi-Way | 1 | 8th January 2008 12:57 AM |
| Precision devices | KevinTams | Subwoofers | 111 | 22nd December 2005 02:41 PM |
| Page generated in 0.10326 seconds (82.17% PHP - 17.83% MySQL) with 11 queries |
