I'm going to build 3-way speakers using subwoofer drivers for bass and my question is about bass reflex so I'm posting it here instead of multi-way forum.
I have calculated reflex tuning with winisd beta and tuning results in way too long reflex port to fit inside the enclosure. I'm planning to build reflex port as rectangular version to be part of the enclosure. I have been thinking of building reflex port as labyrinth into the enclosure. I'm afraid that 180 degree turns affect tuning. Is the reflex port in the picture incorrect way to build it into the enclosure? Does it ruin the reflex tuning somehow? |
#2 |
If the port is to scale please check your sims as the vent area looks small and you may get port chuffing.
The length of the port does put you into the realms of transmission line/horn enlosure design-if you are using BBpro you can "add port resonances" to your SPL output graph. Give me the TS for the sub and proposed port area/length/box volume and I'll do some sims for you. |
#3 |
I'd consider switching to winISD Pro - its a much better tool for these things, as it includes things like driver excursion, port velocity, and options to add crossovers, parametric eq, in fact, pretty much everything you could want until you get to Hornresp.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#4 |
The driver is peerless sls 6,5 inch type 830946
http://www.lautsprechershop.de/pdf/p...ss_slsw639.pdf The box in the picture is not in scale. It would be 10 liter box excluding the reflex port. Tuning frequency would be 25Hz with reflex port: 182 mm x 12 mm opening resulting in length 95,80 cm. I have already built two subwoofer-speakerstands in this fashion and I'm worried about tuning frequency of those too. Those subwoofers have peerless xls-10 and if I remember correctly in 40 liter box tuned at about 20 Hz, but excursion below 25 - 30 Hz increases worryingly instead of below 20 Hz. |
#5 | |
Have a look at this picture to see what is the rec. minimum slot-height for 25 Hz when no losses is expected: b |
#6 | |
The last one is probably the trickiest of all. Basically, as the volume of air in the box and the volume of air in the port get smaller, they become more resistive. And as they become more resistive, you get further and further away from the ideal behavior that's assumed by the model. But there's good news! You can sidestep all of these nightmares by just buying a Woofer Tester from Parts Express. Just measure the impedance curve and adjust the port accordingly. The difference IS NOT subtle - I've seen boxes where I had to hack the port down by nearly half, or even worse, boxes where the port wasn't even behaving like a helmholtz resonator at all! The problem gets worse when ports get longer, or the box gets smaller, or both. Vented boxes can be incredibly frustrating this way. But the Woofer Tester is cheap, I couldn't live without it. |
#7 |
In that box with that port the first port resonance will be at 179Hz, so unless you are crossing HP to that driver lower than 80hz you will have problems. Second, the port ratio is 1:15 (height:width) which is way to high, 1:4 is generally the maximum ratio before you have to derate the port because of surface friction.
The real question is how high (Hz) will the bass driver be used? That will determine the longest port you can use before port resonances become a problem. I suspect passive radiators will be the answer to your tuning problems. It almost always is when using a box that small. |
#8 |
Thank you all for enlightening me about the matter. I truly appreciate new information. It is always great to learn something new.
I will be using active car crossover autostudio cxa-5e and crossover frequency will be 80Hz with 12db/octave. Woofer tester and/or passive radiator exceed my budget so I can't use them in this project. I would like get near flat bass response to at least to 40 Hz. Using closed box seems like a bad idea since electronic correction would require more amplifer power than I can afford. Still it seems like only way to achieve proper response. I don't know enough about transmission line solutions to design them. Instead of flaring ends of reflex port I thought that leaving about 4 times the port diameter to both throat and mouth would be enough and making actual port diameter large enough to avoid chuffing. Is the closed box way to go? What kind of box would you build for this woofer? (not restricting box volume) Are there better computer programs for designing subwoofer than winisd? |
#9 |
Try ~15Liters tuned to 35Hz
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#10 | |
| Quick bass reflex port question... | revans | Everything Else | 26 | 8th March 2009 06:36 PM |
| Reflex port question | Tarzan | Multi-Way | 13 | 1st March 2009 02:31 PM |
| Bass reflex port question | Javachip | Multi-Way | 12 | 11th April 2006 12:11 PM |
| bipole and reflex port question.. | AudioGeek | Multi-Way | 8 | 14th December 2004 09:55 PM |
| Reflex port under the cabinet ?? | gary f | Multi-Way | 21 | 26th October 2003 10:17 PM |
| Page generated in 0.11200 seconds (82.78% PHP - 17.22% MySQL) with 11 queries |
