Old 23rd December 2011, 08:29 PM   #21
Scott L is offline Scott L  United States
Default That's great news
Originally Posted by AndrewT View Post
what is the displacement of a 12" driver with an Xmax of 5mm.
Volume Displacement For SPL Chart
shows the inch units (imperial) for displacement for 50Hz and 110dB to be about 15 to 20 cub inches.
the next post shows the centimetre units (SI).
I would expect a single 12" driver to get pretty close to your SPL target.
I told you not to guess.
I can't make heads or tales from that chart, but if you say one 12 inch unit is enough, than using 2 per will give me 6 db headroom. Thanks !!
Crest Factor ... how does one use it? Don Snyder Subwoofers 8 17th November 2010 04:03 PM
Bl factor vs enclouser type Ndreams Subwoofers 1 26th August 2008 07:19 PM
Damping factor Cro maniac Chip Amps 29 8th May 2004 01:16 PM
actual measurements of compliance and motor force factor capslock Multi-Way 5 27th November 2002 07:15 PM
Bl conversion factor masterp2 Multi-Way 6 28th February 2002 03:38 PM
Page generated in 0.05938 seconds (68.87% PHP - 31.13% MySQL) with 11 queries
