#31 | |
![]() col.
http://www.minirig.org.au |
#32 |
@bko69: so nice build, looking forward to get started myself! Looking forward to see more pics + measurements? Thanks for inspiring + sorry for hijacking!
@Xoc1: I thought of the exact same thing in bed tonight! HERE's my try: TH-scaling & modelling |
#33 |
The glue is finally done! 3 weekends and lots of sticky fingers. it's all down hill from here. just the finish work to go. i had 2 helpers helping me other wise the gluing would have take a lot longer.
more photos can be found at this link i have not thought far enough ahead to figure out what i'm going to do for grills. where do i get them? will they rattle? will they be to restrictive? anyone have any input about grills? bob |
#34 |
Parts Express have got metal grills on special at the moment. You can cut to size using a angle grinder with a cutting disc.
col.
#35 |
I can't wait till you report on these, I am extremely happy with 4, I can only imagine 8 of them.. I used 2 this weekend at a sweet 15...
You can see the subs behind my facade, in the middle... ![]() Quite a few people attended...
The best DJ in Houston using the SS15 born in diyAudio from Jbell and the rest of the community!! |
#36 | |
Grilles were discussed quite extensively in the TH18 Thread JBell posted am example of a basic grille here.... TH-18 Flat to 35hz! (Xoc1's design) A grille will make a significant difference to the strength of the cabinet as it reinforces the weakest part of the speaker enclosure. TundraLTD did some interesting sims in akabak using a 50% open ares grille that showed minimal differences to the response of the speaker TH-18 Flat to 35hz! (Xoc1's design) Regards Xoc1 |
#37 |
Wohoo PARTY!!!
Regards, Dan |
#38 |
fhperez: nice photos. everything is so nice and clean. are those qspot 260s i see?
sorry did not answer your question about how i will stack them. i think i'm going to do 2 clusters of 4, sideways with mouths touching in the center. i'll post a photo later when they are done. not sure if i will center stack them (like i should) or split them up 4 on each side. guess i can try it both ways. bob |
#39 | |
Depending on the venue layout, and coverage desired, center, side or spaced arrays are all what "should " be done. |
#40 | |
Thanks for your pics... I know sometimes I get caught up in, "can I get a db more if I do..." kind of thing.... I love seeing pics showing folks having fun. After all... if it's not fun, you're not doing it right.... thanks |
| FS: B&G Neo8 x8 | Tenson | Swap Meet | 9 | 16th August 2012 01:25 PM |
| EV X8 crossover | lonestarguitar | PA Systems | 2 | 2nd August 2011 01:07 PM |
| Air leak in ss15 TH severely affect output? | m R g S r | Subwoofers | 21 | 26th April 2011 05:23 AM |
| New??? Dac NOS X8 with Tube output | jeffjazz | Digital Line Level | 0 | 4th February 2010 05:25 AM |
| WTB: TDA1543 chips x8 | drjlo | Swap Meet | 1 | 9th June 2008 07:49 PM |
