Old 10th January 2012, 01:00 AM   #11
Didn't even see his 'more pics' link at first
But, even better, like this:
or
What he has now will be better than no holes of course
Old 10th January 2012, 11:02 AM   #12
Sorry, I meant width, not "with", -any suggestions?
Originally Posted by $$Maan View Post
hm, that might be a good idea! But the system volume is a bit bigger in th-18 Actually i thought it was possible just to change between speaker sizes only by changing the WIDTH, like "tda-audio" have done with his 12" subs.
Old 10th January 2012, 04:49 PM   #13
fhperez is offline fhperez  United States
Send a message via AIM to fhperez Send a message via MSN to fhperez Send a message via Yahoo to fhperez Send a message via Skype™ to fhperez
I will be following this build for sure, what is your intended use? I have 4 and JUST LOVE THEM!! Bass from 4 is unreal, so I can imagine 8!!!!
The best DJ in Houston using the SS15 born in diyAudio from Jbell and the rest of the community!!
Old 10th January 2012, 11:35 PM   #14
bko69 is offline bko69  United States
I got the first 3 partially glued up last weekend and a 4th one glued up all the way so i could listen to it. all i can say is WOW 1 sounds great! i cant even imagine what 8 will sound like. i woke up the sleeping baby while testing, the wife was a little mad at me.
2 corner reflectors need to be added and the last side.
The finished one whistles and chuffs lots of air out of the holes in the back where the casters bolt on and through the speakon connector holes. will sound better when the holes are sealed up.
I do a lot of proms and homecomings. i already have a huge light system and I need a large sound system to go with it. i'm hoping i can book more proms when i have a system that can put out lots of bass.
will be gluing the other 4 next weekend. PL premium is sticky stuff. it gets on everything. don't forget your rubber gloves!
bob
Old 11th January 2012, 01:42 PM   #15
How do you plan on stacking them up? I am thinking of going more into proms this year...
Old 11th January 2012, 07:38 PM   #16
col is offline col  Australia
col's Avatar
I have a question about this design, what happens if i scale it up?
In a regular horn it's possible, but TH's are usually just being wider.
I have a birch ply box measuring 70cm/28" X 90cm/36" X 60cm/24"
The ss15 has scalable size 60cm/24" X 75cm/30" and driver 15"
Scaling up everything makes:
60x70/60=70 cm
75x70/60=87,5 cm
15"x70/60= 17,5"
Very close to the box i have with an 18" driver
This would be easy.
Perhaps I'm better of modelling it all over in hornresp?
adding path lenght until the system volume reaches the volume of the cab.
Iv'e been thinking the same thing. I'm about to re-box 4 18"s. I looked at Xoc1's TH-18 and it is just a little bit to big and won't fit in my transport. My maximum height restriction is 95mm.
col.
http://www.minirig.org.au
Old 12th January 2012, 12:37 PM   #17
Loos like we have to sim it for ourselves. If i can get the right hornresp sim-screen for ss15 it should be quite easy to scale up all measurements including driver to get a sim for a 18" 60x70x90 version.
But I'm a bit confused about this tapped horn simulation, can anyone point me to the right input screen for jbell ss15?
Old 12th January 2012, 04:01 PM   #18
epa is offline epa  Netherlands
bob
hi bob.
looks good(sorry about the wife)
do you have any means to measure the responce of one and multyple subs.
the reason i ask is,there is a discusion going on here ,about wether multyple tapped horns lower the f3 corner as to 1 tapped horn.
some say it doesn't ,hornresponse says it does.
it would be intresting to see the outcome.
grtz erik
one good thing about music ,when it hit you feel no pain.
so hit me with music
Old 12th January 2012, 04:28 PM   #19
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
col.
Scaling up the SS15 takes a bit of patience.
The SS15 and the TH18 have the same internal width 533 / 535 mm, no problem there! It could be wider depending on construction and timber cutting reqirements.
The 18 version would probably require 18mm Ply.
There are scaling issues as the SS15 is carefully 'compromised' to allow it to be cut from one 8' x 4' sheet, and you don't need to with the bigger cabinet.
I had some time on my hands and came up with this version.
Note the S2 dimension does not completely follow the model, Its an idea I am working on at the moment. The dip in the sim at 100Hz will probably be smaller due to inductance and the smaller throat size. Width is 533 internal at the moment.
The dimensions could be varied a bit to suit. but are all related to each other in differing ways...
Current Driver is the B&C TBX100. What driver do you have?
Regards Xoc1
Old 12th January 2012, 07:22 PM   #20
i have an SPL meter. i could take some measurements with that. but i don't think that will be very accurate. is there another way to take measurements? i have a DBX RTA mic if that can be used to get measurements some how.
bob
FS: B&G Neo8 x8 Tenson Swap Meet 9 16th August 2012 01:25 PM
EV X8 crossover lonestarguitar PA Systems 2 2nd August 2011 01:07 PM
Air leak in ss15 TH severely affect output? m R g S r Subwoofers 21 26th April 2011 05:23 AM
New??? Dac NOS X8 with Tube output jeffjazz Digital Line Level 0 4th February 2010 05:25 AM
WTB: TDA1543 chips x8 drjlo Swap Meet 1 9th June 2008 07:49 PM
Copyright ©1999-2013 diyAudio
