Speakerholic
Originally Posted by leadbelly
No no; his wording is awkward but he is basically saying that you can either use line level or speaker output connections to the Polk, not that you use both at once.
Originally Posted by Michael Chua
Leadbelly is correct. Connect one or the other (ie only the RCA or the Speakers Input). Not both at once.
OK thanks, misunderstanding at this end. I was reading that if you use the high level ins that you were now using your receiver to power the sub.
BTW I also have a PSW110.
Cheers.
