What 15" driver would you recommend for a 3.75 cu.ft. vented cab that should be capable of doing 40 Hz? 95dB/1W/1M in the passband or thereabouts should be good enough. This is going to be used to provide some additional bass for some PSX-153 cabs that I've restored. In fact, the cabinet in question that's going to be used for the sub is an empty PSX-153 cabinet (it's too expensive to replace all of the blown drivers and the blown x-over, so I'm trying to repurpose it).
The B&C 15PS100 15" Woofer (http://www.parts-express.com/pe/show...number=294-673) seems like it would be a decent match. Any other suggestions worth consideration?
www.diysubwoofers.org |
#2 |
That B&C looks great IMO. Models very nicely for response to ~40hz with a 3.7ft^3 box tuned to ~39hz. Sensitivity is estimated to be more like 95db@100hz, diminishing to ~92db@40hz. Pe is excursion limited at ~540W (very impressive), good for ~120db@540W@1M from 40hz up.
---------------- More than likely, to get 95db sensitivity from 40hz up would require a driver with much less Xmax. What sort of maximum drive levels are you looking for? Eric Last edited by mdocod; 16th December 2011 at 04:00 AM. |
#3 |
Found this: RCF L15P540 15" Woofer Speaker 294-860
from 50-100hz it's about 2db more efficient in the 3.7ft box size than the B&C. Xmax limited Pe is about 420W (tune box to 45hz). Result is higher maximum output through most of the listening range than the B&C (~1db advantage), with the B&C being able to play louder in the 40-50hz range IF you feed it more power... Differences are pretty minuscule but this is so far the only other driver that pops out at me as competing with the B&C around the same price. There are some more expensive drivers out there that may perform slightly better. |
#4 |
Hi Brian,
Check the 'old' RCF 15P200AK, it's a proven concept for almost 30 years and 'updated' in 2010. Used in the EAW SB150 for instance. Last edited by Djim; 16th December 2011 at 05:36 AM. |
| Looking for a driver to pair with PE 0.25 cu ft cabinet | gus6464 | Full Range | 12 | 14th March 2012 03:43 AM |
| reasonably priced 4ohm 15" driver with low Vas to use in vented subwoofer? | sadams | Parts | 0 | 25th February 2011 08:00 PM |
| Need 10" (12") driver for 30 ltr enclosure. (1.1 cu.ft) | Fasen | Subwoofers | 2 | 25th March 2010 03:18 PM |
| Straight 40 Hz corner horn - only 1.4 m (4.6 ft) long! | rick57 | Multi-Way | 13 | 18th December 2005 12:10 AM |
| Page generated in 0.09024 seconds (73.59% PHP - 26.41% MySQL) with 10 queries |
