Atomic Audio ELE 12 12" driver
See Atomic Loud Speakers
Specs as follows:
Re: 1.8 Ohms
Fs: 50.7 Hz (!)
Sd: 0.055 M^2
BL: 20.06 TM
Cms: 75 uMN
Mms: 130g
Qms: 5.38
Qes: 0.37
Qts: 0.35 (!)
Vas: 32.4 litres (!)
Le: ??
Xmax: 10 mm
Pe: 2kW (!)
Specs suggest that this might be a good match for a 40 Hz TH...
Can't seem to find a price for the driver anywhere though...
Specs as follows:
Re: 1.8 Ohms
Fs: 50.7 Hz (!)
Sd: 0.055 M^2
BL: 20.06 TM
Cms: 75 uMN
Mms: 130g
Qms: 5.38
Qes: 0.37
Qts: 0.35 (!)
Le: ??
Xmax: 10 mm
Pe: 2kW (!)
