Is There a smallish prosound tapped horn 35-80hz
If you can I would highly reccomend the LB1560 instead of the LB15-1, I have found that in general it just sims better in TH's. This is as low as I could get a design with decent SPL and still <200L, I'm sure some of the guru's could improve on it and I'm sure that the folding scheme here isn't the best.
