need high-amp DPDT toggle switch for speakers
Old 18th February 2012, 04:48 PM   #11
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by cyclecamper View Post
What's the standard for the 1/4" jack. With + on the tip, should the cone move in or out?
What's the standard for wiring the NL4 for two drivers (mostly interested in polarity)? Wire one driver to which pins, other to which, and which way should the cone move with + on which...
Positive voltage on the 1/4" tip should move the cone forward (away from the magnet) on a standard front loaded box.
NL4 pins 1 are LF, + should move the cone forward (away from the magnet) on a standard front loaded box.
Pins 2 are HF, + should move the cone forward (away from the magnet) on a standard front loaded box.
There are some variations in NL4 wiring, the above is the JBL SRX series standard.
Old 19th February 2012, 10:48 PM   #12
cyclecamper is offline cyclecamper  United States
"Positive voltage on the 1/4" tip should move the cone forward (away from the magnet) on a standard front loaded box."
Check! Thanks!
Now i'm confused. Are the NL4 marked 1/2/3/4 or 1-/1+/2-/2+ ?? I'm going to have to go to Guitar Center or someplace like that to get an NL4 plug, as my sockets are wired and covered with several layers of shrink-wrap, and mounted. I'll get a numbered plug and use my meter...
Old 20th February 2012, 12:32 AM   #13
Speedskater is online now Speedskater  United States
Speedskater's Avatar
One of the SpeakOn papers has the following information:
one NL8MPR socket
low frequency pins 1+/1-
low mid frequency pins 2+/2-
high mid frequency pins 3+/3-
high frequency pins 4+/4-
Positive signal on speaker pin "+" produces positive waveform
from driver (moves cone outwardly)
"+" = In phase (high) "-" = Ground (out of phase, low)
Lower numbers for lower frequencies.
Kevin
Old 20th February 2012, 05:41 PM   #14
weltersys's Avatar
Four conductors, pairs labeled 1-/1+ 2-/2+.
Old 8th April 2012, 11:50 PM   #15
OK I found the markings on a plug, so with a meter I can easily find the associated wire from the jack now.
And + is also red for binding-post terminal strips?
Old 9th April 2012, 03:47 PM   #16
bentoronto is offline bentoronto  Canada
I use this switch for phase reversal testing on my giant OB. Not that I've ever been able to choose the right phase in my whole life. Got it for a school science project around 1949. Works good, always has. Center off. Great design, eh. C'mon, no laughing.
Ben
great weather in Toronto
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio; it was my personal pet project when I was a scientist at the premier Bell Labs at Murray Hill, home of the world's largest anechoic chamber
Old 9th April 2012, 04:06 PM   #17
Yes, they work better than most, and the DPDT is just what's called for. But the risk of damage is also great. A toggle is pretty well protected if I recess it. But I don't think I'm going to bother with any switches anyway. Instead I would probably use some Neutrik jacks with plugs wired in various ways.
need high-amp DPDT toggle switch for speakersHide this!Advertise here!
b&k st-140 toggle switch replacement thezaman Solid State 4 11th August 2013 04:28 AM
double DPDT switch? aussiebuddha Construction Tips 6 10th June 2013 05:57 AM
Using a dpdt switch as on/off? haakok Parts 6 3rd May 2009 05:55 PM
toggle switch with LED on tip for t-amp mod? gychang Class D 4 18th September 2006 05:54 AM
Looking for dpdt switch jeff5x0 Parts 2 28th February 2006 08:35 PM
Copyright ©1999-2017 diyAudio
