Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendation - Page 12 - diyAudio
Old 29th December 2011, 03:01 PM   #111
tb46 is offline tb46  United States
Hi permo,
The finish depends so much on where and what.... I've used just about everything from latex and acrylic paint to 1/4" plywood (ash looks-and finishes-nice) with edge trim to burlap. You can always round the corners, and paint it black.
Maybe a grill for the opening:
http://www.parts-express.com/pe/show...number=260-424
and, some vinyl speaker covering:
Vinyl Speaker Cabinet Covering Black Bronco Yard 54" Wide 260-760
Oliver
Old 29th December 2011, 03:38 PM   #112
I think i have a winner
RustOleum.com
with a satin poly topcoat.
Old 31st December 2011, 03:32 AM   #113
i am just updating the folks who helped me so much with this. I have ordered a grill, 1 50 foot rool of the speaker sealing foam (1/8th X 3/8th) and also the primer, paint and poly sealent to finish the project. I should be done in a month...but I will post pics at every step.
The next step is going to be to pre drill, sand and do a dry run of the removable front and rear panels before we shoot it with primer. We are going to prime, wet sand, prime, wet sand, until we are satisfied...then shoot the hammer finish black and finish it with satin varithane poly. It's nice to have a painting/staining room at your disposal!
Old 3rd January 2012, 01:51 PM   #114
The enclosure was fitted with the removable lids yesterday. Also yesterday we applied the woodfiller, chamfered all of the edges to soften them and sanded the entire enclosure so it will take the primer better.
Tomorow we will move it to the paint room for the first coating of primer.
Old 3rd January 2012, 05:00 PM   #115
Hi permo,
Have you run a sound test yet?
Oliver
Old 4th January 2012, 02:02 AM   #116
Originally Posted by tb46 View Post
Hi permo,
Yes sir, some very light testing and the sound was good, so I am moving forward with finishing.
Old 4th January 2012, 03:21 AM   #117
Hi permo,
Great. Will you be able to perform some measurements?
Oliver
Old 4th January 2012, 03:30 AM   #118
Hi permo,
I did just procure an 11 function audio system test generator, but I have no O-scope, so I am working on that piece of the puzzle.
Old 12th January 2012, 06:07 PM   #119
I will be doing the final sanding of the enclosure and panels next week and also shooting the primer. I should have a finished product in around a Month.
The Function Generator that I have is a BK Precision 3010.
Old 12th January 2012, 06:39 PM   #120
Hi permo,
Take a look at the Linkwitz Lab site:
System Test
Linkwitz sells some test CDs, and has some good information on building an inexpensive but good recording microphone. You should also have a simple hand-held SPL meter, they are just handy. Lots of information on that subject on the web.
Oliver
Tang Band W8Q-1071F sealed box help? droidsocket Subwoofers 3 30th March 2010 10:14 AM
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Questions about the Tang Band W8Q-1071F 8"x12" Subwoofer MyNameIsJake Subwoofers 4 26th January 2008 02:57 AM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang Band W8-740C box design help manxam Multi-Way 4 25th February 2004 04:09 AM
Copyright 1999-2017 diyAudio
