Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendation
Old 9th December 2011, 03:16 PM   #11
tb46 is offline tb46  United States
Hi permo,
Looks like bjorno's design from Post #3 will work well.
There are a few small errors in the lower right hand corner of the picture: S1 (the opening close to the drivers) should be S4, and S4 (the close end of the duct inside the box) should be S1; in general, all the S's refer to the cross-sectional areas of the tube (or duct): S2 is on the side of the drivers (pick the middle between the two drivers) pointing towards the closed internal duct, and S3 is on the side of the drivers (again, in the middle between the drivers) pointing towards the mouth. S1 is the throat (close end in this case), and S4 is the mouth (opening close to the drivers). All the L's (e.g.: L12) refer to the distances between the S's.
I highly recommend you spend some time in Hornresp, there are a number of good tutorials on the web.
Oliver
Old 9th December 2011, 03:28 PM   #12
permo is offline permo
Originally Posted by tb46 View Post
Hi permo,
I have spent the better part of the last month in horn response and have went through numerous tutorials. I think my problem is understanding the different types of horns and converting the numbers to an acutal box.
I can make a simple tapped horn fairly easily in hornresp, but I don't understand the difference between the designs and how hornresp is doing what it does.
Old 9th December 2011, 03:45 PM   #13
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
First: tb46
Quite correct: I seem to do this all the time,Thanks Oliver!
Originally Posted by permo View Post
...but my brain can't quite wrap itself around the concept well enough yet...
If you are not in a hurry we can help you to sort out concept issues...
Submitting a picture revision of what Oliver have noticed here-above:
b
PS: The important distance here is L23 but L12 can be slightly off easily to correct with the necessary needed damping material. This can be shown in simulations, i.e. by using MJK:s or the AKAbak program.
Old 9th December 2011, 03:54 PM   #14
Hi bjorno,
You are welcome, you put so much work into these designs, and help so many builders, you deserve a little help every now and then. :-)
Oliver
Old 9th December 2011, 04:02 PM   #15
Hi bjorno,
Thank you Oliver,I really appreciate your help ....
b
Old 9th December 2011, 07:14 PM   #16
I have all the time in the world, I am doing this project as a side project related to a larger one. I am finishing my basement and this is a great chance to integrate the 7.1 system into the room.
I appreciate the help so much. Is there two openings or just the one by S1? How much space do I need between the internal baffles/dividers and the adjecent outer walls?
The lid is actually part of the enclosure wall, but removable to give driver access I assume?
Old 10th December 2011, 12:07 AM   #17
revboden is offline revboden  United States
revboden's Avatar
Movies you say, my specialty I like those two drivers in a 4ft^3 ported box tuned to 25Hz with a 3" x 10" slot port 27.6" long. pic below. This design would let you upgrade to a 500w amp and have reference spec.
Old 12th December 2011, 01:56 PM   #18
Still trying to put a cut sheet and dimensions together for the horn. I have some questions. I totally understand S1, S2, L12, L23..etc..etc.. here are my questions
1. Does each horn segment have to be a certain internal volume or am I more concerned about hitting my S and L variables appropriately?
2. How big/long do I make the opening?
I am starting to wonder if the lighbulb is ever going to get lit for me, regarding these horns!
Old 12th December 2011, 02:47 PM   #19
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
I just started playing with hornresp myself tonight...
In one of the guides I was reading, S2 can be as small as 1/4 the Sd of the driver, but many drivers will work better with this dimension being larger. This is the "throat" or compression area so it's fairly important that this not be any larger than the Sd from my understanding (I could be wrong on this so someone feel free to chime in). It's also important not to go smaller than 1/4Sd as I guess that can cause problems.?
The same guide said that a good starting ballpark for S4 is driver Sd x 2 but this may change as you optimize the simulation.
Old 12th December 2011, 03:51 PM   #20
After simming your driver in hornresp awhile, I'm convinced that this horn loading stuff is a lot more hype than anything. The best arrangement I could come up with produced similar efficiency and loading characteristics as the 6th order bandpass box I suggested above, however, the box would be nearly twice the size, and perform ~3db worse in maximum output compared to the 6th order bandpass configuration.
Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendationHide this!Advertise here!
Tang Band W8Q-1071F sealed box help? droidsocket Subwoofers 3 30th March 2010 11:14 AM
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 6th June 2009 12:37 AM
Questions about the Tang Band W8Q-1071F 8"x12" Subwoofer MyNameIsJake Subwoofers 4 26th January 2008 03:57 AM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 04:37 AM
Tang Band W8-740C box design help manxam Multi-Way 4 25th February 2004 05:09 AM
Copyright ©1999-2017 diyAudio
