Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendation
Old 27th December 2011, 02:54 PM   #91
tb46 is offline tb46  United States
Hi permo,
The size of the slot @ S4 is 4.672"H x 8.625"W, from the area in Hornresp: S4=260cm^2 (40.3in^2).
I'd make the bottom piece of the front baffle removable too. Make sure you can get to the mounting screws, and get the speaker in and out easily, there is very little room in the width.
Oliver
Old 27th December 2011, 03:00 PM   #92
permo is offline permo
Originally Posted by tb46 View Post
Hi permo,
I have that part. I just couldn't find a template for the sub cutouts. I was able to get a document from T and B and make a general template with trial and error yesterday. We should be good to go.
What do you think would be better?
1. rectangle slot with removable top and bottom front panels
2. Single removable front panel with circular opening?
Once again, I can't thank you eneough for your AMAZING work/help on this.
Old 27th December 2011, 03:43 PM   #93
Hi permo,
For a first try I would go with the round port / single front panel. Pictures? :-)
Regards.
Oliver
Old 27th December 2011, 04:00 PM   #94
Hi permo,
Regards.
I will post pics tonight for sure. Right now I just have a pile of cut up wood and some boards under presses. Tonight, We will be fitting things together, gluing and clamping. The only board I plan on using screws on is the removable front panel. The entire enclosure, without the front will be wood glued then put under a large press to cure/dry. I will then caulk the seems, add bracing and prepare the front.
Is it still a 7.163" diameter port with the center 7.005 inches from the bottom of the enclosure?
Would routing the edge to smooth the port out cause any issues by reducing the volume a little?
Old 27th December 2011, 05:36 PM   #95
Hi permo,
Yes, the port location and diameter have not changed. Sounds like you have a nice woodworking setup. Are you using braids to hold the boards in place prior to clamping?
Oliver
Old 27th December 2011, 05:39 PM   #96
Hi permo,
I wish it was mine. I have a retired chemical engineer/perfectionist friend with a massive workshop in his basement and two more (including a machine shop) on his property.
The boards are cut accurately within 1/128th of an inch, and we will be mitering the bottom edge of the slanted board at the exact angle for the design.
I will post pics of the project tonight. Hoping to get everything braced, glued and under the press tonight, excluding the front. That will be last.
P.S. It is becoming apparent that this speaker will not be easily transported. It is going to be HEAVY.
Old 27th December 2011, 08:00 PM   #97
Hi permo,
You need to provide some access to the S1/S2 section to be able to change the stuffing. The stuffing is a vital part of bjorno's design.
Oliver
Old 27th December 2011, 08:08 PM   #98
Hi permo,
That was my mistate, the rear is also entirely removable. Just like the front.
Old 27th December 2011, 09:28 PM   #99
Hi permo,
Talking about mistakes, I went over the drawing one more time, and found an error in the length of the long vertical divider board (now: 42.752"). I don't think it matters, but it should ideally be a little shorter than in the original drawing. I also added the dimension for the duct cross-section below the long divider board (1=7.121). See attached drawing.
File Type: pdf T-TQWT_by bjorno_for permo_Rev_02b_correction.pdf (9.2 KB, 92 views)
Oliver
Old 28th December 2011, 02:57 AM   #100
Hi permo,
Hey, no big deal. I made it the other way, but I can sand down the panel once everything drys. Tomorow we will mount the drivers and put the removable panels on. Also cut the circular vent hole.
Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendationHide this!Advertise here!
Tang Band W8Q-1071F sealed box help? droidsocket Subwoofers 3 30th March 2010 11:14 AM
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 6th June 2009 12:37 AM
Questions about the Tang Band W8Q-1071F 8"x12" Subwoofer MyNameIsJake Subwoofers 4 26th January 2008 03:57 AM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 04:37 AM
Tang Band W8-740C box design help manxam Multi-Way 4 25th February 2004 05:09 AM
Copyright ©1999-2017 diyAudio
