#41 | |
Driver is on it's way but probably be a while with the XMas post. Got the MDF though so I'll get cracking over the XMas break. Do you think it would be of any detriment or benefit to put the port as a slot at the very top of the front baffle. (@ S4)? The sub will sit behind the settee and only just peek out from the back, about 5>6"..... a slot would vent to free air rather than into the back of the settee. No way of measuring even though I do have a kit of bits for a mic that never made it Cheers Lee
Damn... why didn't I think of that! |
#42 | ||
The T-TQWT is a pressure source with no directional dispersion and will not reveal its location if placed right and the XO is set properly. You will here all bass coming from your main speakers only. b |
#43 | ||
Excellent of course.. The picture showing the HR IR is almost impossible to interpret unless the impulse is magnified and chopped into small pieces in order to give any on psycho acoustic observation based reliable clues of the perceptible performance. I find any attempts to base assumptions on how a T-TQWT/T-QWP or even a multi-folded TH will perform viewing the HR IR to being an utterly impossibility. Have a look at the submitted picture to get a clue. b Last edited by bjorno; 15th December 2011 at 11:47 PM. |
#44 |
#45 | ||
The question I was asking was comparing the SW182 with the WF182. Which one would be preferable in a tower application? a. The SW 182 has more Xmax (better excursion) but higher Le see figures 4-6 in the pdf below http://www.wavecor.com/SW182BD01_in_..._Feb._2010.pdf OR b. The WF 182 has lower Le but has limted excursion see figure 3-5 in the link below Voice Coil - Voice Coil April 2011 Since you have experience with Wavecor, how well are they built compared to the L18 or L22 from SEAS Prestige or 18W8546/8545 from ScanSpeak? Quote:
WT-1427G - TB speakers 10 inch subwoofer - Europe Audio Then again the larger 10" woofers would need to go on the side of teh cabinet and not on the front baffle is teh cabinet front is required to be narrow. That might affect how/where the driver is crossoved over.
...still looking for the holy grail. |
#46 | |
On the pict I joined with my and your sims, one could see a 5dB difference. I try to know why ? Did I entered wrong values ? Why the Eg on mine is 30.98 ? Thx for the answer / IR , it's more clear now. ![]() Cheers. |
| NAKAMICHI reference slimline monitors woofer retrofit.... | ching0n | Multi-Way | 1 | 22nd June 2011 01:07 AM |
| Computer DJ laptop vs. slimline PC | 96tahoe | Instruments and Amps | 4 | 15th May 2008 08:57 PM |
| zaph slimline wall mount | blue934 | Multi-Way | 4 | 17th May 2007 02:05 PM |
| slimline stepping power supply's | karma | Swap Meet | 2 | 6th August 2005 01:49 PM |
| a slimline floorstander project using FE206E | luigi | Multi-Way | 1 | 5th August 2004 02:32 AM |
| Page generated in 0.16656 seconds (54.95% PHP - 45.05% MySQL) with 11 queries |
