Which type of box would you build based on this frequency graph?
Old 21st December 2011, 09:40 PM   #21
Cokewithlime is offline Cokewithlime  Canada
Originally Posted by judderod View Post
Looking at these pictures there's a huge volume inside the sofa. Only trouble is some walls are very flimsy, and some walls are just the sofa's foam. No way to calculate anything I guess. How about a big thick sheet that seals off the entire bottom section with the driver in the middle?
It will work well enough (in fact may surprise you)
Here are the downsides, having tried this myself.
- the back and arm outside areas of the sofa are generally only supported by cardboard or very thin plywood - not at all rigid and will definitely resonate at various frequencies - that coupled with the close proximity of the fabric/leather sofa covering causes loud buzzing / slapping at those resonant frequencies.
- the LFE effects will definitely pressuize the inside of the sofa and anyone sitting on it will "feel" the LFE effect as well as hearing it - my wife did definitely did not like this during normal music playback and we both got tired of it after playing the second movie - so it got ripped out and went back to a "normal" sub box design
Old 21st December 2011, 10:07 PM   #22
weltersys is offline weltersys  United States
weltersys's Avatar
The OP already finished his sofa sub.
LFE Sofa
Old 21st December 2011, 10:11 PM   #23
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by BP1Fanatic View Post
How can the distance between S3 & S4 be less than 1/2 the diameter of the speaker?
Hint(s):
b
Which type of box would you build based on this frequency graph?Hide this!Advertise here!
Does anyone have the TAD TL-1601a and Exclusive ET-703 Frequency Response Graph? HP8903B Multi-Way 27 22nd October 2012 08:02 PM
goldwood GM-65/4 frequency graph mcmahon48 Multi-Way 0 10th December 2008 09:27 AM
W-type and the G-box baffles Riche Lemuey Subwoofers 4 4th July 2007 09:46 AM
Why does the BiB's frequency response graph go all spazzy, and why can't we hear it? Spasticteapot Full Range 6 7th November 2006 09:56 AM
frequency response graph acceptable? tech.knockout Multi-Way 15 28th June 2003 05:23 AM
Copyright ©1999-2017 diyAudio
