I have i Diy 2.5 Cufeet enclosure tuned to 18 Hz, by 12 inch wilson watch dog driver crossed over at 50 Hz. Now since i am using a car amp class D 750 watts, i need to boost the signal as putcompared to the balanced in output going to krell . The subsonic filter built-in amp is at 20 Hz, and i am using BFD with Q=1, Fo=20 Hz gain= +12 db.
Sounds much better now at lowest end but times the woofers seems to loose control and sound buzz buzz one note only .....its annoying some times as compared to bass from mains i.e B&W 802 but some times for LFE wobble and awe are too good too good to believe. BTW the driver is from wison audio watch dog subwoofer. |
#2 |
How did you tune a 2.5ft^3 ported box to 18Hz?
#3 |
On this page the specifications suggest that flatish response to 18 Hz is achieved by cutting frequencies above it! That's the only way I can explain the awesome 83 dB @ 1Wm sensitivity...
Regards, Ben WATCH Dog Passive Subwoofer: Woofer: One - 12 inch Dual Spider (30.48 cm) Sensitivity: 83 dB @ 1 watt @ 1m @ 100 Hz Nominal Impedance: 8 ohms/minimum 5.6 ohms @ 1 Hz Minimum Amplifier Power: 200 Watts (for theater applications) Frequency Response: 15Hz - 300Hz Room Average Response Overall Dimensions: Height w/ spikes – 26.875 inches (68.26 cm), Width – 18 inches (45.72 cm), Depth – 25.125 inches (63.82 cm) Weight: 211 lbs (95.7 kg) Total Shipping Weight (approx): 281 lbs (127.5 kg) Wilson Audio: WATCH System (Specifications) |
#4 |
i got the dimensions from wilson specificatons... approximately. tuned with 4 inh pipe 24 inch long. why do you think it should have greater volume ? BTW its Fs=38 HZ. QTs=0.55
| Where's the bass from an 18" Audiobahn AW1805Q in a 12cf vented enclosure? | Max Caliber | Subwoofers | 45 | 12th April 2011 04:53 PM |
| Modifying 4-band semi-parametric to fully parametric with shelving? | diymixer | Construction Tips | 3 | 5th July 2010 06:38 AM |
| David: Small vented loudspeaker with bass boost | Dominique | Multi-Way | 4 | 21st May 2008 03:17 AM |
| Discussion about LT versus Vented subwoofer designs... | simon5 | Subwoofers | 6 | 25th April 2005 08:26 AM |
| Looking for a good <70€ mid-bass, and nice <30€ tweeter | Bricolo | Multi-Way | 53 | 19th April 2003 10:02 AM |
| Page generated in 0.22277 seconds (32.24% PHP - 67.76% MySQL) with 10 queries |
