Old 1st December 2011, 02:16 AM   #11
freddi is offline freddi  United States
freddi's Avatar
here's the basic info I got on a freshly reconed DL18 - new qes is ~0.6
factory spec EV 18B
FS - 33
Qts - .36
Qes - .376
Qms - 8.37
DL18 reconed with modern kit
FS - 36.7
Qts - .4895
Qes - .599
Qms - 3.963
Le - 1.793mH
Old 23rd December 2011, 07:18 PM   #12
freddi's Avatar
its difficult to get more than 1mm peak to peak at loud levels in my room with EV18B and it reaches a K-tube so transients sound "fast"
Old 24th December 2011, 12:55 AM   #13
Originally Posted by freddi View Post
I've got an empty 18" coupler which to try an EV - Art - do you know if MacKenzie's recone assemblies including the voicecoil are accurate reproductions?
Hi Freddi: Would you post the dimensions and "K" curve for the 18-inch Karlson you pictured? I'd like to construct one for my EV -18 reconned driver. I've not WT-3ed them yet. ....Michael
Old 24th December 2011, 01:17 AM   #14
freddi's Avatar
I don't have a drawing anymore but will get some dims - I think the wings are P=1/Q=1.7 up to a point then that's extended with a de-Q-ing slit- you could go with the Gauss 5181 K18 plans which has a bit more front and rear chamber. 18's will work in the regular Karlson K15
Cetec-Gauss 5181
http://img72.imageshack.us/img72/825/gaussbracing.jpg
here's a 5181 build - the guy was happy
http://gainclone.com/karlsonforum/index.php?topic=42.0
Vogel's "Lowest Noise" pre-am drdagor Analogue Source 0 3rd May 2011 04:12 PM
What is "mass loading?" chrusion Subwoofers 8 15th January 2011 05:47 AM
suggestions for the "lowest noise" pentode Majestic Tubes / Valves 6 1st December 2004 09:42 AM
"mass added to cone" I'm confused about it's meaning Jimmy154 Multi-Way 12 8th July 2002 02:53 AM
Page generated in 0.12131 seconds (53.68% PHP - 46.32% MySQL) with 11 queries
