Lowest mass 18"s in production -?
Old 28th November 2011, 03:45 PM   #1
freddi is offline freddi  United States
freddi's Avatar
Default Lowest mass 18"s in production -?
A Karlson builder is looking for an improvement over the Eminence Sigma which has ~130g mms. I had a pair of Eminence 18s made in the 1990's with 103g mms and qts=0.25. AA Craaft made an 18" IIRC with 77 grams mms. The game for his 18" K-coupler is to try to get the lowest moving mass together with a strong motor. Peavey offers 122g mms but their published spec of qes is near 0.5 (too high) plus it may be worse than that in reality. Without going to a custom build, is there anything which will beat the Sigma in regards to lower mass and good motor for this application?
Old 28th November 2011, 11:29 PM   #2
weltersys is offline weltersys  United States
weltersys's Avatar
EV DL18X has a QTS of .34, total moving mass .069 kg.
The EVM-18B Series II has a QTS of .36, probably similar total moving mass.
The original EV 18-B was probably lighter in the voice coil department.
The 18-B is a pretty "poppy" 18.
Old 29th November 2011, 10:30 AM   #3
freddi's Avatar
thanks Art! - I love to have one in good shape for myself for an 18" K-coupler laying around. DL18X must be rare. There's some really beat 18B (II?) on Ebay right now.
Old 29th November 2011, 08:35 PM   #4
weltersys's Avatar
Freddi,
I remembered another unusually light 18" used in a TOA 480SC, a three way speaker with a 1" exit mid horn and a small tweeter. The cone seemed to be quite compliant, (soft)but I have no TS parameters or even the cone model number.
Looks like the acoustic crossover is around 800 Hz, pretty high for an 18.
The speaker sounds pretty good, if you could get the horn up to ear level, not so easy with a 100 lb all in one cab.
Did a fair amount of listening to it at a friend's house, and was surprised to find it was an 18", I had never seen a commercial 18" cross to a small 1" horn before.
Art
Old 30th November 2011, 03:10 AM   #5
bentoronto is offline bentoronto  Canada
It is an odd and disquieting thing that some speaker systems (like resonant BR) seem to "optimize" on drivers which don't seem right in other respects. Like having excessive mass to their cones or not the strongest motors possible.
I think the Karlson (and OB) do not have these aberrant inclination. Sure liked mine.... back in 1956.
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio
Old 30th November 2011, 11:02 AM   #6
freddi's Avatar
I've got an empty 18" coupler which to try an EV - Art - do you know if MacKenzie's recone assemblies including the voicecoil are accurate reproductions?
Old 30th November 2011, 06:06 PM   #7
weltersys's Avatar
No experience with MacKenzie.
My only experience with non-OEM recones were JBLs using Waldom parts, not only were they 3dB less sensitive, they sounded like crap.
With the high cost of recones, I'd just look for a decent old EV18-B, there were tons made.
Check Minneapolis St.Paul Craigslist, just between me and my brother, we had 30 or 40.
Bill Batson, a reconer at Metro Sound & Lighting in St.Paul might know where to find one.
By the way, I have a pair of 8" Jensen Wizzer cones in Karlsons that you really should have, I'd trade for some raw woofers if you are interested.
Art
Old 30th November 2011, 06:19 PM   #8
freddi's Avatar
I've no mobility to even trade stuff and when giving away an item and haaving no printer, UPS goofed up things. The driver I'm looking at uses a MWA parts recone - the seller is supposed to provide a WT3 report - will that conform the potential crappiness?
Old 30th November 2011, 07:56 PM   #9
weltersys's Avatar
I don't know what a WT3 report is.
The only way I know to tell if a driver is "good" is to do an A/B test with a known good one, hard enough to do with new stuff, much harder with decades old drivers.
Old 30th November 2011, 10:33 PM   #10
freddi's Avatar
WT3 is Dayton's version of a "woofer tester" to automatically gather parameters from a quick Z-sweep. Old drivers = yeah - I'll probably take a chance with an old 18B
Lowest mass 18"s in production -?Hide this!Advertise here!
Vogel's "Lowest Noise" pre-am drdagor Analogue Source 0 3rd May 2011 04:12 PM
What is "mass loading?" chrusion Subwoofers 8 15th January 2011 05:47 AM
suggestions for the "lowest noise" pentode Majestic Tubes / Valves 6 1st December 2004 09:42 AM
"mass added to cone" I'm confused about it's meaning Jimmy154 Multi-Way 12 8th July 2002 02:53 AM
Copyright ©1999-2017 diyAudio
