What Sub/Subs for FOH Tour Rig What Sub/Subs for FOH Tour Rig - Page 3 - diyAudio
Old 29th November 2011, 04:21 AM   #21
PutSomeAmpsIn2It is offline PutSomeAmpsIn2It
Spoke with my EAW rep today and he referred me here: http://www.eaw.com/products/jfl118/d...pec_prelim.pdf
Since I'm not up on interpreting the specs/data what are observations on this sub?
Old 29th November 2011, 03:05 PM   #22
weltersys is offline weltersys  United States
weltersys's Avatar
Looks like another ported box to me.
The cabinet has flyware, a very expensive feature that you will not be using in clubland, unless you already own chain motors and all the associated rigging gear.
Not much data to go on, no chart and "preliminary", meaning "subject to change". The 100 dB sensitivity spec is probably at around 120 Hz, the operating range are probably the 10 dB (or more) down points.
10 dB down sounds half as loud, and requires 10 times the power to flatten out the response.
If you want something that will make some real bass without needing massive power check out my Keystone design or the TH-18 design.
Keystone Sub Using 18, 15, & 12 Inch Speakers
To give you an idea of their output, a single Keystone 18 (BC18SW115-4 loaded) with a bridged Crest CA-9 can put out slightly more 40 Hz level than four Meyers 650P dual 18 cabinets.
I run a pair (one per side) with fourteen horn loaded 8" and five 1.5" DH1A (3" VC ) per side on top.
Crossing over at 100 Hz, the subs and the mids run out of steam at about the same level.
Art Welter
Old 29th November 2011, 05:05 PM   #23
epa is offline epa  Netherlands
agreed the eaw is nothing special.
you could probaply bild 3 of those diy for the same price.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
What Sub/Subs for FOH Tour RigHide this!Advertise here!
a Bryston tour! lanchile Solid State 2 22nd March 2011 02:23 AM
Need Advice on Sub Testing Box rig and Options for Rig Oborous Subwoofers 8 29th November 2006 11:14 PM
Transmitter e-tour mashaffer Tubes / Valves 6 27th February 2006 05:31 AM
Has anybody seen this tour ? zmurray Everything Else 0 1st September 2005 07:11 AM
V A N H A L E N ........on tour.....YESSSSSSSSSSSSSSSSSS tbla Music 5 14th April 2004 06:03 PM
Copyright ©1999-2017 diyAudio
