Hi there, about to build a pair of ported 90l eminence lab 12 subwoofers tuned to 25hz. Want to power them with a behringer ep 2000.
Anyone know the easiest way to set up an adjustable low pass filter (like the variable knobs on active subwoofers eg 50-100hz). Also want to have a fixed high pass at 20 hz. Input would be line level.
I would be grateful if you could tell me the easiest way of doing this both both digitally and analogue. Thanks.
This should give you ideas:sorry by line level meant rca.
http://www.diyaudio.com/forums/subwoofers/200320-active-crossover-tapped-horn.html
There are plenty of cheap and easily adjustable active crossovers for car use, they'll be 12v powered and 2-way,. They won't have a "subsonic", but these can be easily made on the RCA input side-I have seen a link on here, or get one of these: FMOD (Filter Module) High Pass RCA Level Crossover
