#11 | |
Low 30 Hz is now common in music, I see response in to the 25 Hz range frequently on my RTA, though music mixed for the vinyl era usually has little below 50 Hz. While I agree that starting to fall off at 40 Hz is plenty low enough for the majority of (pop) music, there is plenty of music that I listen to that having flat response to below 30 Hz makes a real difference. Art |
#12 | |
For music yes. But I was just pointing out that 40hz isn't considered "deep bass" on a forum were people build very large HT oriented horns tuned to 20hz or below. |
#13 |
#14 | |
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way! |
#15 |
Thanks for putting that into better perspective. In that context, you are correct sir.
#16 | |
FYI: Horn Size: Height 224.8 cm....~7.375 ft Width 204.0 cm (from wall to wall diagonally)....~6.693 ft Depth 100.6 cm (From front to wall corners)....~39.6" Net Volume 1990 liters....~~ 70.28 cu.ft Gross volume of 2300 liters (estimated)....~81.22 cu.ft b |
#17 | |
Because of that, with some music one can get away with EQing as much as ten dB of boost to counteract a falling response without any excursion problems. However, kick drums and synth content for some music may have as much 25 Hz as 50 Hz, with a 10 dB boost either massive clipping or overexcursion will occur. All depends on the content (compare the movie soundtrack "Inception" to a girl with an acoustic guitar, LOL), and the level one wants to achieve, if the OP is happy with a 40 Hz F3 response, that makes a reasonable size FLH achievable if room walls are employed in the design. |
| Entering horn meaurements fora folded horn (hornsrep) | Tidy Max | Software Tools | 3 | 21st February 2011 02:28 AM |
| My custom folded bass horn | carpenter | Subwoofers | 5 | 29th January 2011 06:20 PM |
| how to go from horn response to a folded bass horn design? | paulspencer | Subwoofers | 8 | 4th November 2005 10:44 PM |
| Deep bass makes me sick? | Paradise_Ice | Car Audio | 15 | 23rd June 2004 03:12 PM |
| 18" Folded Bass Horn Design | djdan | Multi-Way | 11 | 27th October 2003 09:21 AM |
| Page generated in 0.14827 seconds (64.81% PHP - 35.19% MySQL) with 10 queries |
