Do I need to buy a capacitor for the system in my car?
Old 19th November 2011, 02:38 PM   #21
epa is offline epa  Netherlands
the link you provided state's "
  • RMS Power Rating:
    • 4 ohms: 170 watts x 2 chan.
    • 2 ohms: 250 watts x 2 chan.
    • Bridged, 4 ohms: 500 watts x 1 chan."
so thats 500 watts 4 ohm bridged
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 19th November 2011, 03:01 PM   #22
18Hurts is offline 18Hurts  United States
I took a look at the specs
500 watts bridged into 4 ohms and it is a 2 ohm stable amp. 170x2 channels into 4 ohms is the actual rating and it is class AB.
It is NOT stable into 2 ohms bridged! Rewire your sub for 4 ohms with the two 2 ohm coils in series for 4 ohms and report back.
It has a stock 40 amp fuse and you have a 100 amp alternator--you should be fine if it is running 4 ohms and your battery/wiring is decent.
Get a multimeter to read DC voltage, connect it to the battery and run it up. Get the maximum voltage reading and the minimum voltages on the battery. Do the same thing at the amp, that will tell you if your dropping voltage across any connections.
Don't worry about the "1,000 watt peak" rating--that is mysterious marketing since even at 14.4V with the engine running, 1000/14.4 = 69.4 amps if your amp were 100% efficient. I am guessing the 500 watt rating bridged also assumes 14.4 volts for a fraction of a second. Marketing watts are 1/3rd the size of normal with that 40 amp fuse is the tell tale sign but such is marketing.
If you can get a known good battery, the biggest you can stuff in the car and take voltage readings--then run it around for awhile, if the alternator is not charging over 14 volts, you need a new alternator.
Lead Acid batteries have 6 cells connected together, they run around 2.0V each. Fully charged cells are 2.4V each so 6 cells X 2.4 is 14.4V for a fully charged battery. If one cell starts failing, it can give you a bogus 14.4V reading since it is fully charged with almost no capacity. If a bass hit drops the voltage from 14V to 12.5 with the engine running, or it drops from 12.5 to 10.5V with the engine off--you have a bad cell so time for a new battery.
Wire the amp correctly, swap out the battery for a known good one and take some readings with the volt meter. A good skill to know and it will clear it up for you. It is also something you should have laying around if you mess with car audio--check the voltages on the wires and when wiring dual voice coil subs--it tells you if you wired it correctly. Your sub wired with series voice coils should be around 3 to 3.5 ohms--if it is wired for one ohm, it will be around 0.8 ohms which is not what you want.
Old 23rd November 2011, 09:47 PM   #23
familyguy9877 is offline familyguy9877  United States
familyguy9877's Avatar
Problem solved, when I finally found the time to wire it for 4ohms it fixed the problem. thanks to everyone who contributed
More BASS!
Old 23rd November 2011, 09:52 PM   #24
Congrats on getting the over current condition solved!
Hope it was educational for you and your next build goes much smoother.
Do I need to buy a capacitor for the system in my car?Hide this!Advertise here!
Disconnecting Capacitor from system jrgolfpro Car Audio 8 6th March 2009 10:28 PM
Want to buy UCC 678D capacitor Sunsun22 Swap Meet 0 4th June 2008 09:38 PM
car audio system needs help stephen22 Class D 14 13th March 2006 06:32 AM
PIC Of My system in the car Dj BASS AMP Car Audio 10 10th January 2004 10:38 AM
Where can buy Mallory CGR capacitor? PRBS Solid State 5 5th November 2002 03:03 PM
Copyright ©1999-2017 diyAudio
