Old 17th November 2011, 12:07 AM   #21
Measured with the amps turned off right?
QSC amp input is 10.11 K ohm (20hz high pass)
Denon amp input is ?? (45hz high pass) i cant get a consistent reading on it!! ill keep trying
Preamp output impedance is 2.11 K ohm
Old 17th November 2011, 12:24 AM   #22
Zero D is offline Zero D  United Kingdom
So the QSC amp has a fixed (20hz high pass) & the Denon amp a fixed (45hz high pass) Is that correct ?
And they are MONO ? If they are then you will Only need 2 x the circuits as shown
It would be much better if you could get the input impedances from the manuals, if you have them. If not try & look them up on the www. Either way post back with what they state Then we are good to go
Old 17th November 2011, 02:15 AM   #23
frugal-phile(tm)
planet10's Avatar
Originally Posted by jbell View Post
FMOD Crossover
An FMOD is an expensive & often less than optimal Passive Line Level Crossover (PLLXO).
This is what ZeroD showed in Post #18. His is the 2-pole version using the input R of the amp as the 2nd R. Because of loading issues, the input R of the amp ether needs to be highish (say 50k plus), or the preamp has to have vanishingly low output impedance.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th November 2011, 03:55 AM   #24
nooo...those are the high pass points which i am looking for. there are no high pass filters on either amp right now. (well the qsc has selectable 30 or 50 hz, neither which i want for my 20hz sub)
the QSC amp is bridged, and the subwoofer output of the onkyo 607 receiver is mono, sooo i'm guessing they are both mono then?
the qsc input impedance is listed as 10k unbalanced, 20k balanced. so the reading i got was pretty darn close.
i've searched high and low for ANY specs on the denon plate amp i have...its from a denon powered subwoofer. dsw 40 is the only model info on the plate amp. i can't find any info on it, except the obvious that i already know. (powered 8" subwoofer...)
Old 17th November 2011, 03:58 AM   #25
dave
well the qsc amp isn't that high, and the output of the receiver was measured as 2.11 K ohm....is that "vanishingly low"?
if not, and this is a bad idea to try this kind of high pass, then i'll just order the mini DSP.
Old 17th November 2011, 04:11 AM   #26
frugal-phile(tm)
planet10's Avatar
Those impedances would suggest that you are limited to 1 pole.
dave
Old 17th November 2011, 05:48 PM   #27
Good idea, less than 24 dB per octave HP does not afford great protection and wastes power on subs that already drop off at 24 dB per octave acoustically.
Old 17th November 2011, 05:58 PM   #28
I just ordered it. The 2 x 4 Guess it'll be useful for other projects / tests as well!!
Old 17th November 2011, 06:55 PM   #29
@ m R g S r
All the best with your decision
Old 17th November 2011, 06:56 PM   #30
Thank you for willing to help!!
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
high pass filter prabanjas Chip Amps 1 9th October 2009 01:37 PM
Just to check - Is my high pass filter ok? revans Parts 21 11th March 2009 01:40 AM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
Low/High Pass Filter fatpower17 Car Audio 1 28th June 2004 08:45 AM
Page generated in 0.11781 seconds (77.71% PHP - 22.29% MySQL) with 11 queries
