Location: Lawrence, a nice little college town in Kansas
I found someone was having a special on a pair of Peerless 830855s (don't remember who). It's the smallest driver I've ever seen described, by the manufacturer, as a subwoofer - 4"!
http://www.tymphany.com/files/SDS-P830855%20Rev1_0.pdf The idea of a 4" subwoofer intrigued me and I figured I could use them for my computer. I measured impedance with Dayton's WT3, and modeled them with Audua's Speaker Workshop (I never trust manufacturer's specs). Even though Tympani's data sheet said they're ideal for sealed boxes, SW modeled a much better response for a pair in a 14.3 liter ported enclosure tuned to 53Hz. As you can see in the photo, I put them on opposite ends of the same 14.3 liter cube with a single port, even though they will be driven by separate amplifier channels. After building it I was disappointed with the very loud chuffing, and a loud resonance when playing a 45Hz test tone. Next day, I did some nearfield measurements of both drivers, and of the port with Holm Impulse. The two drivers were driven by separate channels being fed the same signal. I had to take time-aligned measurements of the two drivers separately, sum them, then sum that response with the time-aligned port response, all in Impulse. I then taped an extra 1cm, 2cm and 3cm on the end of port and repeated the measurements. I got a much nicer response with an additional 2cm on the port. I was a bit surprised because usually SW's calculations are spot-on. All-in-all I'm impressed with what Peerless can get a 4" woofer to do. Some people may be wondering whether or not they can be used as a full range driver. I would not recommend it. I listened to some music, and thought the mids were pretty muffled. This project got me wondering just what a subwoofer is. That is: how does a driver described as a "subwoofer" differ from the same size driver described as just a "woofer". Is it their inability to play mid bass, and a need for a low X-over point? Just wondering if anyone has any ideas. Last edited by ByronInLawrence; 13th November 2011 at 11:01 PM. |
#2 |
Banned
Yes, thicker cone, heavier, generally more excursion etc, things that rob it of accuracy help bolster it's performance at a lower frequency.
#3 |
Hey Byron,
Is the (Volume of Sealed Box) 35.311'³ used in the VAS calculation?
Regards, Dan |
#4 |
Neo Dan,
-Byron |
#5 |
you interested in ~35hz?
Regards, Dan |
#6 | |
![]() I always thought of sub-woofers as just that, a driver with a Fs 20-30Hz that filled in below the woofers (~60Hz). But I'm just an old IATSE sound engineer, most of my career I only used Subwoofers for "effects" so what would i know. later, rev. |
#7 |
No to 35hz eh? How about 40hz, it's smaller and a bit more efficient.
This is 1/2" sheet stock. ~17-5/16" x 6" x ~29-7/16" hwd
Regards, Dan Last edited by NEO Dan; 14th November 2011 at 02:00 AM. |
#8 |
Hi NEO Dan,
I don't understand the question. I'm not planning on building any more subwoofers for a long time. -Byron |
#9 |
Hey Byron, I remembered seeing these Tang Band subs in a PE flyer and thought you might be interested. Maybe it's the upper freq response that is used to categorize subwoofers? I'm also intrigued by little subs that can provide usable output <50Hz. Looks like a neat PC multimedia box you've put together. Where did you set the LPF?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#10 |
FYI, A less than 1 liter box suggestion using two TB-W2-1625SA: b |
| Smallest possible subwoofer enclosure | Peezlepop | Subwoofers | 2 | 17th April 2011 03:10 AM |
| World's Largest Subwoofer | orangeshasta | Everything Else | 9 | 27th July 2008 03:06 PM |
| Oki Electric Industry intros "world's smallest MP3 chip" | Nordic | Parts | 1 | 16th September 2006 10:21 AM |
| The world's sexiest finish? | The Dudster | Multi-Way | 8 | 8th November 2004 12:41 PM |
| World's Ultimate Subwoofer? | dantwomey | Subwoofers | 10 | 21st April 2004 12:21 PM |
| Page generated in 0.14439 seconds (71.31% PHP - 28.69% MySQL) with 11 queries |
