15" kicker l7 30hz box design help !!
I have a 2011 Kicker L 7 dual 2ohm subwoofer that I am trying to design a box for that can do 120+ db's @ 30hz.. anyone got anything that they think will work? any and all suggeestions are greatly appreciated.
1 Attachment(s)
I hadn't forgotten about you... A front loaded horn is all I came up with.
30Hz tapped pipe
2 Attachment(s)
Since he has a 30Hz HPF in the amp I gave it a little bump :D
so since I am slow what are the dimensions of this beautifull beast. ?? either that or I can sell the kicker if you think there is an alternative sub in the $200 price range that I should use.. once again thanks for all the help
clarification. i meant on the inside pieces Neo Dan on this beautifull looking box..
The baffle board the driver bolts to splits the inside dimension in half, and the 'end' of that board is the same dimension front, top, back. Everything else is brace. |
6 Attachment(s)
jbell is right on about the bracing. I used 4" 5" & 6" holes in the drawing as an example.
Here you go: |
looks easy enough guess time to get some wood and have a sunday funday cutting and gluing
I try!
http://i111.photobucket.com/albums/n...asybutton2.jpg Don't forget the pics! Do you have any measurement equipment? |
4 Attachment(s)
SATISFIED!! box is done. I have lights going out from them being rattled, parts of my house shaking i have never seen before. This box is amazing finally satisfied 1 15" kicker and 2 3015lf's all in a stealth setup behind the tv.. Thanks everyone..
| All times are GMT. The time now is 01:53 PM. |
Copyright ©1999-2013 diyAudio
