My First TH design - Page 2 - diyAudio
Old 11th November 2011, 10:38 PM   #11
Zero D is offline Zero D  United Kingdom
Originally Posted tb46
You found some interesting graphs that I normally don't use, and you may want to ask David McBean about them.
I will
For displacement I look at the Diaphragm Displacement window (after clicking on Calculate) after setting the input power under Eg (double-click Eg).
On doing that it looks fine, but using the graphs i did, not very I'm hoping DB will clarify where i'm probaly going wrong
For limits I look at the Maximum SPL Tool from the SPL Response window. E.g.: set Maximum driver input power in watts to: 1500, and Maximum diaphragm displacement in mm to: 12.5.
Doing that i get limited to 100W @ Xmax ?
I'll post back after i hopefully get to the bottom of it
@ j.michael droke
Hi, Thanks for your info Hopefully my above post explains more about the issues i'm experiencing.
@ Xoc1
I agree it's quite "compact" Thanks for the heads up
@ bjorno
Good suggestion, Thanks
Old 12th November 2011, 03:30 AM   #12
Hi there ZD: I ran your input data through HR and found the following results:
input Fane 18500 Fs=36, Re=5.4, Qt=0.31, Qm=10.17, Qe=0.31, Vas=151.06L and:
at 21hz, 123.7db, 12.2mm disp., 58v and 130.6db 26hz to 83hz +3.6db -2.0db..comment:
(reasonably close to your HR) (not flat at +3.6 -2.0) and:
a filter cutoff needed protecting the Fane from exceeding 12.7mm displ. below21hz
I do not see that you are in error for HR, however others here have commented on the size and applicability to fit the Fane in to the folds....regards, Michael
Old 12th November 2011, 03:31 PM   #13
tb46 is offline tb46  United States
Hi Zero D,
This is a follow-up to my above Posts #3 and #7, as well as to the questions you asked in the Hornresp thread, Post #2444: Hornresp
Hope this helps.
Oliver
Old 12th November 2011, 11:05 PM   #14
@ j.michael droke
Hi, thanks for the info
@ tb46
Thanks I'll study it.
Sound Design, a new book on innovative and interesting ideas in speaker design. Studio Au Multi-Way 3 8th April 2012 08:46 PM
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
My new design of differential buffer I/O board for fully balanced design alant4321 Solid State 28 28th July 2011 09:53 AM
Metronome style design for multiple drivers, a number of design questions mountainhick Multi-Way 5 28th January 2010 03:31 AM
Copyright 1999-2017 diyAudio
