diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   Please help ID this 18" woofer (http://www.diyaudio.com/forums/subwoofers/200137-please-help-id-18-woofer.html)
airegin 9th November 2011 09:33 AM
2 Attachment(s)
Anyone know this 18 inch ? any use for home audio ?
thanks!
epa 9th November 2011 02:04 PM
deffenetly (semy)pro audio.
that magnet is huge.
best measure the ts parameters ,then you know how to use it.
revboden 9th November 2011 02:48 PM
looks like an older Peavey driver. What is the Re?
m R g S r 9th November 2011 02:51 PM
must weigh a ton!
airegin 9th November 2011 03:07 PM
8 ohm dcr, 20 kg weight.
Max Caliber 9th November 2011 03:40 PM
Hi Airegin
The cone and especially the basket both resemble the JBL 2240 but the magnet is something else. For a while there were many overseas Asian manufactures that openly copied the 2240. If it is a knockoff of the 2240 then I would be very cautious about using it as a HT sub woofer as it would lack the Xmax needed as it would easily bottom out on infrasonic signals, unless a low-cut filter was used below 30 Hz. For music it would probably be acceptable, however beware that many of the Asian woofers produce unacceptable (to me at least) amounts of distortion (lack of internal shorting ring etc).
Cheers
PJC
revboden 9th November 2011 04:04 PM
That would make it a ~12ohm driver. I'd measure the rest of the T/S specs. would probably make a very nice woofer.
one concern, the cone looks to have been creased then repaired, could just be the picture though.
Dag Johansen 9th November 2011 04:12 PM
It have been in a horn or a bandpass box, you can see the dirt, from air passing thru the gasket, on the surround.
(and on the screwholes on the back of the basket)
Dag
NEO Dan 9th November 2011 04:39 PM
Is China's finest PA woofer with 5" voice coil, a knock off of the PD1850.
djk 10th November 2011 08:55 AM
http://i551.photobucket.com/albums/i...chy_01/019.jpg
Void Acoustics V18-1000
Resources saved on this page: MySQL 18.75%
