Old 8th November 2011, 05:16 PM   #1
Default audiobahn aw150t enclosure help
hi all new member in need of some advise
just wanted to no what dimentions the enclosure will have to be for optimimum bass with a slot port
thanks
gaz
Old 8th November 2011, 05:20 PM   #2
Speakerholic
Cal Weldon's Avatar
I have moved this over to the woofer section.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 8th November 2011, 05:22 PM   #3
ok nice one
just to add its a 15 inch 1200 watt sub
Old 8th November 2011, 07:43 PM   #4
epa is offline epa  Netherlands
some ts paramaters would be helpfull
one good thing about music ,when it hit you feel no pain.
so hit me with music
Old 8th November 2011, 10:45 PM   #5
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by gazgolfgti View Post
..just wanted to no what dimentions the enclosure will have to be for optimimum bass with a slot port..
Hi gaz,
Your driver has a Qts not favored(IMO) for quality BR designs even if using a large long slotted port because the box would ring like a bell unless you stuff the entire enclosure including the port.
See the picture and you will understand my points:
b
File Type: jpg Audiobahn-AW150T-OD-TL_or_Slot-Ported-BR.JPG (478.9 KB, 33 views)
Old 9th November 2011, 01:08 AM   #6
Zero D is offline Zero D  United Kingdom
Lightbulb Bass Reflex
@ gazgolfgti
Hi, here's a Bass Reflex 100L box tuned to 30Hz with 1 x 75mm x 150mm slotted port. 1st port resonance @ 432Hz. Max safe power is limited to 400W though, but still !
Old 10th November 2011, 03:27 PM   #7
FYI, More Simulations:
b
AudioBahn A12001DQ Dr Zeus Car Audio 5 11th July 2011 01:42 AM
Where's the bass from an 18" Audiobahn AW1805Q in a 12cf vented enclosure? Max Caliber Subwoofers 45 12th April 2011 04:53 PM
Audiobahn a275hct 2fast4u88 Car Audio 43 2nd July 2010 09:19 AM
Audiobahn a18001dt audiobahnkid592 Car Audio 13 27th May 2010 02:45 PM
Audiobahn sub skooter Car Audio 1 24th November 2007 04:21 AM
Copyright ©1999-2013 diyAudio
