Where to place the port (part 2) - Page 2 - diyAudio
Old 4th November 2011, 08:36 PM   #11
carshateme's Avatar
The reason I do not want the ports pointed towards my glass is because I had a similar set up in my car before and it decided to blow my trunk lock right off..and put a crack in my back window. About to pay this dude $150 to make it for me because you're confusing the heck out of me.
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Old 4th November 2011, 08:40 PM   #12
I see, you want to port the cabinet for the added low end, then throw the added low end away by having it get lost in the trunk.
Makes perfect sense to me
Old 4th November 2011, 09:19 PM   #13
carshateme's Avatar
Well I came up with a new design, since you are arguing about low ends..blah blah. lol.
New specs:
Box: 32"w x 13"h x 20"d.
Port: 3" w x 11.5"h x 21.5"d
..although it will one tight fit...I will be trying to put the subs on like most subs are...towards the trunk opening, and putting the Slot port in the center with a short divider going about 6" from the wall in the center of the port. Will have a sketch done when I get out of work..
Question can I have a 3" gap between cut around.
Ex. my depth is 20 inch...cut off 1.5in for the walls, gives you 18.5in to play with...so use 15.5in and stop, go over 3 inches from that wall and then 6 in from there.
Old 4th November 2011, 11:14 PM   #14
New specs:
An "L" shaped port will work OK, round the corner. Good idea to round the outside corners too, to avoid chuffing noise.
The extra resistance of the "L" bend will probably tune a little lower than a straight port.
Old 5th November 2011, 12:07 AM   #15
carshateme's Avatar
Alright I got the pictures now.. I want to know your opinion on this one...it was one of my a design for my audiobahn subs...and I'm using L bend as you recommended.
The lines in the center represent the sub and how far it will go in. Now I have already calculated everything carefully...after subtracting the port volume from the box volume and subtracting the sub displacement, I got a box with 3.01 Cu ft volume, which is perfect. The volume recommended for these subs is 1.5. I don't know about the center piece b/w the port...but a guy name barron on here recommended it a while ago. I used it on my audiobahn box, and it works great.
The extra face plate is just insurance that my box won't blow apart...and I don't know think I'll be able to screw the sub in the first layer with out splitting the upper wood. So thus the face plate will be used.
X-ray:
Normal:
Front view:
Old 5th November 2011, 02:46 AM   #16
carshateme's Avatar
I also made another model with the subs upward...pretty much the same specs and such, I favor the first one I made though instead of this...but if it's better, I'd use this one.
Unlike the first one, the ports are 2" x 18.5" x 21" with a 4" bracket in the middle...thought I don't think that bracket is a smart idea for such a small width port.
X-ray:
Normal:
Old 5th November 2011, 03:02 AM   #17
Ah thank you for the picture, I didn't know what he was talking about...now I gotta go look for a triangular port calculator.
Calculate the area of a rectangular port using the triangle port "leg" dimensions. Divide by 2. Divide the answer by "pi". Take the square root of the answer. That gives the equivalent round port radius. Multiply by 2 to give you the equivalent round port diameter. You can also calculate this backwards if needed.
Old 5th November 2011, 03:10 AM   #18
carshateme's Avatar
Too much work...for a lazy person lol.
Sticking with the slot port.
part circle port calculation jayam000 Subwoofers 2 27th February 2010 07:08 AM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 06:45 AM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 10:26 AM
can I place a port? Tony.ca Car Audio 1 17th June 2003 04:43 AM
Copyright 1999-2017 diyAudio
