Need Opinions on these subs
Old 2nd November 2011, 09:18 PM   #1
carshateme is offline carshateme  United States
carshateme's Avatar
Default Need Opinions on these subs
Got two choices here..well 3 but the sundown seller isn't responding to my text so I ain't going to pester him.
But one is 2 12's RE MX series
MX12-D2 Features:
Dual Composite 2-piece Cone
Rubber Surround
Integrated Gasket
Cast Aluminum Basket
Tork-Tite Terminal
4" 4-layer Aluminum Voice Coil
FEA Optimized Motor Structure
Powerful Neo Magnet
Dual Progressive Spiders
Integrated Tinsel Lead
MX12-D2 (MX.12.D2/MX12D2) Dimensions:
12" Dual 2ohm Subwoofer
Mounting Depth - 10.25"
Mounting Hole Diameter - 11.5"
Overall Diameter - 13"
Bolt Hole Circle - 12.25"
Motor Width - 8.5"
Motor Depth - 2.5"
Basket Depth - 7.75"
Displacement - 0.19 cu. ft.
Weight - 33 lbs.
MX12-D2 (MX.12.D2/MX12D2) T/S Parameters:
Electrical Q Value -Qes: 0.503
Mechanical Q Value -Qms: 3.206
Total Speaker Q Value -Qts: 0.434
Free Air Resonance -Fs: 23.165 Hz
Equivalent Compliance -Vas: 59.0 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 83.5 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.4 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 1500 W
Force Factor -Bl: 14.56
MX12-D2 (MX.12.D2/MX12D2) Recommended Enclosures:
The other sub is a 2 12" DC level 3 subs
Mounting Depth
6.75"
11"
Motor Width
6.5"
Weight
20lbs
VC Diameter
3"
Displacement
.15 ft
Magnet Weight
17.5lbs
Power Handling RMS/Peak
600/1200
Impedance (Ohm)
d2 or d4
Sd
494.00 cm^
Vas
74.15 L
Cms
2.17e-04 m/N
Mms
145.73 g
Fs
28.3 Hz
Bl
22.18
Re
5.89 ohm
Le
5.06 mH
Qms
8.11
Qes
0.59
Qts
0.55
Xmax
22.5 mm
Sensitivity
86.40 dB
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Need Opinions on these subsHide this!Advertise here!
Audio Art 15" subs. Opinions? bradonline Subwoofers 2 15th January 2008 04:54 AM
Opinions on Focal subs cody6766 Subwoofers 3 11th April 2006 07:56 AM
What are your opinions on Dayton's IB Subs??? cody6766 Subwoofers 9 3rd March 2006 05:28 AM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 01:44 AM
2 subs one box/2 subs 2 boxes vetkilr Subwoofers 5 22nd February 2006 10:27 PM
Copyright ©1999-2017 diyAudio
