#11 |
For one driver:
Qtc .38 3.9 cubic feet Qtc .4 3.4 cubic feet Qtc .45 2.5 cubic feet Qtc .47 2.23 cubic feet Qtc .48 2.12 cubic feet Qtc .49 2 cubic feet Qtc .505 1.8 cubic feet Qtc .6 1.255 cubic feet Qtc .707 .85 cubic feet Last edited by cyclecamper; 3rd November 2011 at 11:24 PM. |
#12 |
Download WiniSDpro (free) for excursion, power handling etc. You can scale whatever your using to see low response, i.e. setting Fs x 5 will show a response of 20 to 500Hz equal to 4 to 100Hz. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#13 |
Boxes are larger than I thought.
So I'm guessing if I mount (adjusting the box volume for the space occupied by the speaker(s): 1 driver in the cabinet it's about 2.2 cubic feet, Q just below .48 2 pairs of 2 clamshelled drivers in two holes in the cabinet it's a similar 2 cubic feet, Q around .49 2 clamshelled drivers in one hole in the cabinet, it's equivalent to 4.4 cubic feet, ridiculaous Q around .38 |
#14 |
sreten, so where can I get it and will it run on Vista, as my XP machine is down.
#15 |
So, I don't care about the -3db point but
Qtc .38 down 14.61db at 20 hz, down 10.26 db at 30 hz Qtc .49 down 16.49db at 20 hz, down 11 db at 30 hz Doubling the box size it's a little teensie bit better output below 40 hz, but any noticeable improvement is below 25 hz, if it can make the excursion. |
#16 |
This isn't going to go very low with the stock woofers. Maybe I should look at adding mass to the cones and lowering Fs. So I can measure the new Fs easily enough, but how do I calculate the new Vas and Qts from the old numbers?
#17 |
2 pairs per cabinet clamshelled will down low with room gain. LinearTeam You can add further EQ, a lot easier than cone mass adjustment, but TBH critically damped boxes (Q= <0.5) should sound very good. Having researched this, commercial subwoofers go very low at modest levels, with bass boost, but back off the boost as you approach the excursion limits of the drivers, to prevent overexcursion. These adaptive circuits are common commercially, but not in DIY. Line level passive EQ bass boost is very simple for Q=0.5 boxes. see : Baffle Step Compensation but think 30Hz rather than 300Hz as the centre frequency. Lowering the lower resistor will increase maximum relative bass boost available. Though a better solution (in max SPL respects and perceived extension at the limits) might be a peaking high pass filter set to Q = 2 to 3 set to as low as you want to go. rgds, sreten. Might as well point out the drivers with such a low Q are not really suited to sealed or isobaric ideally, and individually vented very low in boxes you would end up with a monstrous low end capability, lots of big boxes though.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 4th November 2011 at 12:43 AM. |
#18 |
Well, I didn't make the best choices but practical ones. I'm stuffing 4 (2 clamshelled pairs) into each box for Q .5 with a brace installed. It's not going to go as low as a tapped horn could, but with 4 boxes that's still 8 12" drivers exposed to room air and they have acceptable xmax, so it's going to make plenty of bass in the more-perceived range. If I want more lower, I might get some more of the same cabinet kits and load them up with 2 15's clam-shelled isobaric in each. Yes, big ported boxes would have a lower -3db point. But I'd hoping these put out something detectable even lower. I will see soon enough. Few more weekends of construction. I sure wish I hadn't sold my table saw.
| Tempted to build a sub out of JL Driver | Howard | Subwoofers | 3 | 14th August 2006 04:19 PM |
| Pioneer F9 tuner | Praudio | Everything Else | 0 | 15th February 2005 06:04 PM |
