Hi.
I got a two the box 15-300/8a loudspeakers.
parameters http://images1.thomann.de/pics/prod/193264_specs.pdf
But i don`d know what type box to built?
I think i want two box.
120L@45hz box ,but then go xmax to long at 40hZ
Need help to good boxes.
Henri.
Bad english skill...
Henri.
Hi hents503,
This woofer would work in jbell's SS15: http://www.diyaudio.com/forums/subwoofers/170771-single-sheet-th-challenge.html.
Now i made one 320L box@40hz 2loudspeaker one box.
Its so big
Its big its shaking my garage roof but no kick and high SPL...
You're a quick DIY'r. Did you make a closed box or something else?
Submitting a picture containing more calculations.One of the results: One driver in a 300L closed box is not promising normal sub FR extension but only mid-bass BW, at most.
b
Hi hents503,
The thread is in the link in Post #14 above, here it is again: http://www.diyaudio.com/forums/subwoofers/170771-single-sheet-th-challenge.html. In the singlesheet thread there a any number of drawings, to begin with try the drawings in: Post #74 in inches or Post #82 in mm dimensions.
- Subwoofers
- Subwoofer with the box 15-300/8a
