#21 |
one good thing about music ,when it hit you feel no pain. so hit me with music. |
#22 |
Hi Y'all,
After trying this woofer in a number of Hornresp models, the only subwoofer for the driver "the box 15-300/8A" that I kind of like is a front loaded horn (FLH) of about 362 L_net, I'll attach the Hornresp Input and SPL screens. For a suggested construction (and size comparison) see the Vitavox Thunderbolt (estimated net volume = 560 Litres) The unofficial Vitavox website- Thunderbolt. There are lots of nice 15 inch driver FLHs out there, and with Hornresp (and AkAbak) we can actually simulate their response. Regards,
Oliver Last edited by tb46; 6th November 2011 at 04:05 PM. |
#23 |
Hi again,
Just to follow up: Regards,
Oliver |
#24 |
HI!
This box is nice,but i need somthing smaler. 150-100L can make somme good ,or only vented box??? |
#25 |
Hi hents503,
You could try using two drivers in an isobaric configuration: bass reflex (vented), volume=100L, port I.D.=15.24cm, port length=15.24cm. Should be easy to try out if you already have a box, just mount two driver in clamshell fashion, and tune the box. Obviously, all of this depends on the accuracy of the T/S paramerters. Regards,
Oliver |
#26 |
#27 |
Hi hents503,
Yes, front-to-front is usually the easiest to try. Obviously, the electrical polarity has to be reversed on one of the woofers, i.e.: they need to move together in the same direction. For maximum distortion cancellation they should be mounted front-to-front (clamshell) or back-to-back (in a tunnel). Regards,
Oliver Last edited by tb46; 15th November 2011 at 01:39 PM. |
#28 |
HY!
Now i heard some time isobaric. Can some type box ise more effectly than isobaric?More kick and db. And smoler than 150Liter |
#29 |
Hy!
question,can 1x mccauley b184 18´´ driver or 2x the box 1-300-8a 15´´ drivers ? I don´t find mccauley sensitiv 1m/1w? |
#30 |
sory, mccauley b1840 is correct name
I simulated bass box pro6 and i got125db into 120L@50hz ...? And 2x the box 15/300/8a into 300L vented box is 125db max I think mccauley driver is better? much moor kick and db and smal box? Henri. |
| Anyone got any dead JBL M115-8 (or 8A) 15" drivers? | GordonW | Swap Meet | 1 | 18th October 2007 04:31 PM |
| 15" Sub Box | chainenoble | Swap Meet | 19 | 13th October 2006 01:29 AM |
| 15" Immortal Subwoofer awis-15 | bil | Car Audio | 0 | 30th May 2006 07:46 PM |
| Brahma 15 For HT (Help with Box) | Fazorcat | Subwoofers | 4 | 13th February 2005 10:51 PM |
| FS: pair of JBL 2225H 15" $300 | spitz | Swap Meet | 0 | 16th June 2004 05:28 PM |
| Page generated in 0.12290 seconds (61.79% PHP - 38.21% MySQL) with 11 queries |
