Old 30th October 2011, 02:26 PM   #1
angeloitacare's Avatar
Default How to get the best bass reproduction ?
The weakest link of my audio system today is bass reproduction. It has very positive aspects, as sounding tight and clean. BUT.....
It is directional, and is not well integrated. It sounds actually disconnected from the main horn towers. Beside this, while my main towers do emanate sound from 1,7m height vertically to the floor, which i very much like, the bass horn is only 1,1m high, and emanates sound only from this vertical size. I would like to emanate at least bass from the same high level, down, as the main horn towers.
There are different methods. the easyest for me would be to build a second, identical bass horn, and place it above the first bass horn. But i am thinking if i might find other configurations, which eventually will work better. Direct radiator and bass reflex line array , open baffle, TH, etc. i would like to know ideas, which could result in my next improvement of my system in the bass region. What eventually could work best ? Any suggestion ?
Angelo
Old 30th October 2011, 03:19 PM   #2
Speakerholic
Cal Weldon's Avatar
If you are finding the bass directional, could it be that the horn woofers are crossed too high?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 30th October 2011, 04:26 PM   #3
GM is offline GM  United States
GM's Avatar
Sounds like you need a mouth diffraction plug same as when using down-firing.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th October 2011, 04:51 PM   #4
they are crossed at 150hz
Old 30th October 2011, 05:08 PM   #5
For many years, I crossed over at 140 Hz 24dB/8ave to a single corner horn. Despite what others say, I assure you there was no sense what so ever of the woofer location on any content I can recall. Moreover, the woofer location was often meters from the rest of the system and easily detected if there were directional effects.
I now cross-over around 110 Hz. Not because of directional effects but because I finally have enough horsepower to drive my Dayton-Wright ESLs lower.
Having a mixed-bass sub is a good idea too. And esp. when you have two or more subs in diversity installation to address room influences.
Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), Klipschorn mixed-bass woofer w/param. EQ plus 1954 AR-1W or giant OB
HiFi construction since 1956
Old 30th October 2011, 08:16 PM   #6
revboden's Avatar
Bad time alignment can also cause a directional cue and disconnected sense.
Old 30th October 2011, 08:47 PM   #7
What's the slope? 150 Hz is high-ish if the slope is not steep; possibly OK if it's 24 db/octave (although I would go a bit lower than 150 Hz/24dB myself).
" ... In theory, there is no difference between theory and practice; In practice, there is. ..." - Chuck Reid
Old 30th October 2011, 08:49 PM   #8
Hi, the shortest answer to the original question is "know your onions", rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 30th October 2011, 09:25 PM   #9
my active crossover has 24db slope. I am looking to try out maibe something different, than i was accostumed to hear until now. For example a dipole line array with H frame, or something as proposed recently by Nelson Pass.....i guess it was ripole, or so....
Old 30th October 2011, 09:27 PM   #10
I can promise you that my system had terrible time alignment yet no directional cues or disconnected sense what so ever. While that's nothing but my admittedly biased perception, I think over dozens of years I or visitors just might have noticed (including times when I was inclined to puzzle my visitors).
It is a common error to note a perturbation of sound which is profoundly evident in theory and on charts and wave traces and think it must be audible. I'd put a large part of talk about hearing phase in that category.
Haas Effect is strong.
BTW, I agree that anything less sharp than 140 Hz and 24dB/8ave likely would be audible, as the math clearly suggests.
On the other hand, my brain does not seem too good at localizing a pure 140 Hz tone in my room, with no help from the Haas Effect, whatever the textbooks say.
Ben
stereo reproduction MJ Dijkstra Multi-Way 5 26th October 2009 05:25 PM
modest cost FR = best bowed bass & cello reproduction? freddi Full Range 7 1st December 2006 06:40 PM
Transient Perfect reproduction Thunau Multi-Way 0 24th July 2006 01:18 AM
My philosophy on audio reproduction RADIOLEE Everything Else 27 8th August 2002 06:35 AM
Big horn or pseudo-infinite baffle for bass reproduction ? Antonio Tucci Multi-Way 11 15th May 2002 10:43 PM
Page generated in 0.50673 seconds (24.21% PHP - 75.79% MySQL) with 10 queries
