#11 |
Hmm, to my way of thinking, no way to answer this correctly without knowing the desired gain BW.........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#12 |
@ bjorno
Hi, bit of a test hey I'm presuming that, fd = fs Qmd = Qms Qed = Qms Vad = Vas Qtd = Qts I'm used to seeing the TSP's written as in the second column ! Well taking into account they all have the same Sd & Fs & Re, based on several factors including, high BL & a stiffer cone & high SPL, it "appears" that A1a "might" be better. What's the word ? @ GM Indeed, but i think i understand why he posted the test |
#13 |
@ bjorno
Hi, can you let us know you're opinions etc please, to Posts # 10 & 11 & 12 |
#14 | |
GM
#15 |
So theres a bunch of terms in designing a tapped horn that are totally alien to me, having worked a bit with loudspeaker design cookbook.
can someone post a list of these and the relevant TS parameters. when designing ported/sealed boxes i would chose a cutoff and driver and hunt for a design that hit most closely, taking into account location and bass lift from it. It was noted above that there are car audio woofers that would do well in a TH. Car designed woofers are often SEVERELY abused thermally and driven at box tuning with thousands of watts. It seems that the stress on the driver in a TH is over multiple frequencies. . |
| Collated Design Criteria/dimensions for Ariel ML-TL Design | talsius | Full Range | 1 | 13th October 2011 05:28 AM |
| Criteria for well behaved clipping | panson_hk | Solid State | 1 | 9th August 2010 02:35 PM |
| se, srpp, pcb design criteria | Electroshocked | Tubes / Valves | 13 | 1st July 2009 08:20 PM |
| Reconstruction filter design criteria. | Aiace | Digital Line Level | 2 | 18th April 2009 09:06 AM |
| Drivers selection criteria. | beppe61 | Multi-Way | 8 | 19th April 2006 04:18 PM |
| Page generated in 0.11482 seconds (64.48% PHP - 35.52% MySQL) with 11 queries |
