I have been wondering...hope you guys can help.
Open Baffle 12" subs set in a H frame.....Instead,could you use a 16" piece of heavy duty PVC pipe with the woofer placed in the center fastened to a wood (or whatever) type of ring? This would leave about 2" around the woofer to the pipe. Would this work? Could you stack 2 of them on top of each other? Problems with this would be....? Thanks
Life in a northern town..... |
#2 |
Quarter Wavelength Loudspeaker Design Gallery
Should be fine, if you look at MHK's gallery, the 7th guy down uses some sonotube, I think this is your idea also? |
#3 |
Thanks, that exactly what I was thinking.
#4 |
Yes, it would work. I'm pretty sure that the dipole peak will be somewhat stronger/bigger with this type of frame, compared to a more traditional rectangular frame.
What length of pipe would you be using ?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
| OB H frame Emin Alpha 15A & CRH-70 - Help needed | andb | Multi-Way | 20 | 5th May 2012 05:22 PM |
| MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame | Jim Shearer | Full Range | 606 | 25th April 2012 11:11 PM |
| MJK OB over H-Frame finished | gvimhoof | Multi-Way | 17 | 31st March 2012 08:29 PM |
| Suggestions please on OB with 15" H frame | syyma | Full Range | 21 | 30th July 2011 11:07 PM |
| Titanic MK3 in OB H frame? | jmillerdoc | Subwoofers | 1 | 2nd February 2011 11:31 AM |
| Page generated in 0.11129 seconds (57.59% PHP - 42.41% MySQL) with 10 queries |
