Old 22nd October 2011, 07:54 AM   #1
Default Boston Acoustics G21244 for home use
I was gifted this sub and I'm thinking of getting a box and a 300 watt rms, 8 ohm plate amp and using it in my two channel stereo/home theater setup. This is a sub intended for car use but can I use it for my home rig. Which type of enclosure would be best, sealed or ported? The spec sheet calls for one cubic foot of volume for sealed and two cubic feet of volume for ported. These are the volume specs for use in a car, would the volume specs for use in a room be different? It has a Qts of .58 and is a DVC and can be operated in either 2 ohms/8 omhs. Any advice, opinions, help will be greatly appreciated. My present home sub is a Paradigm PS-1000 10", 125 watt ported bandpass that I've been using since 1996.
Regards, Sam
Old 24th October 2011, 01:51 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by slovell View Post
Which type of enclosure would be best, sealed or ported? .. Any advice, opinions, help will be greatly appreciated...
Hi Sam,
You could put your driver into a ~133L closed box that return a ~f-3dB of
~34 Hz or IMO better to design an OD-TL enclosure: f-3dB=~21 Hz.
b
Has anybody listened to the Boston Acoustics T830 speakers? Jim85IROC Multi-Way 30 18th October 2011 11:39 PM
Boston Acoustics GT-40 mike49504 Car Audio 20 7th October 2011 02:20 PM
Boston Acoustics S60 Components slovell Car Audio 0 18th December 2010 01:24 PM
Boston Acoustics A150 jamwvu Swap Meet 0 6th July 2007 02:09 PM
Boston Acoustics HD 10 70s music Multi-Way 3 13th June 2007 09:30 AM
Page generated in 0.07228 seconds (59.63% PHP - 40.37% MySQL) with 11 queries
