Need help tuning a box.
Old 21st October 2011, 12:47 AM   #1
carshateme is offline carshateme  United States
carshateme's Avatar
Default Need help tuning a box.
Well I like to "create" boxes on my 3d modeling program before I build it so I know the exact measurements of each side...
SO here's what I'll be working with
*3/4" MDF board, learned 1" MDF is way too much.
Here's the specs for the subs I'll be getting in a few weeks:
RE: 7.09 Ohms
Fs: 28.4 Hz Hz
Qes: 0.511 0.519
Qms: 5.75 7.25
Qts: 0.469 0.484
Vas: 40.3 L
BL: 25.04 NA
Le: 7.7 mH
Mms: 252 g
BL^2 / RE: 88
600 watts RMS
XMAX: 19mm one way
Mounting Depth = 6.5"
Cut-Out = 10 15/16"
Displacement = 0.14 ft^3
Overall OD with Gasket = 12.5"
Enclosure Suggestions:
1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz
* Tune higher and use a smaller box for more SPL oriented setup (Use 1 - 1.5 cubes)
* Enclosure can be as big as 2.25 ft^3 with lower power levels
1.00 ft^3 sealed -- F3 of 44 Hz
* For SQ and space limited applications
*I'll be using the subs for everyday bass/SPL sometimes.
IT WILL BE PORTED.
I would rather have slot ports instead of circle ports, but if circle ports are better...I'll go with them. Will appreciate any opinions.
Just need the port length...for I have no clue how to do it...I'm just good at dimensions and such...
Max dimensions are 33"w x 13.5-14"h x 15-26"d
Will probably want 1.5cu volume for each sub....whatever produces more dB
*I'm new to this. I only won one SPL competition in the summer, got lucky.
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Old 21st October 2011, 01:17 AM   #2
revboden is offline revboden  United States
revboden's Avatar
Design at Subwoofer-Builder.com
get WinISD, Boxnotes, Flare-it
Old 21st October 2011, 01:20 AM   #3
carshateme's Avatar
Thank you.
Old 21st October 2011, 11:39 AM   #4
TheBaronGroog is offline TheBaronGroog  United Kingdom
The box I designed you previously will work fine for these too, I just modeled it and all works out ok.
Need help tuning a box.Hide this!Advertise here!
tuning a box too low? jaygeorge1979 Subwoofers 10 29th July 2016 07:48 PM
Some help with box tuning GOWA Multi-Way 1 26th July 2010 01:13 AM
I need help with box tuning!!! jking29 Car Audio 8 21st December 2005 05:37 AM
Sub Box Tuning Fazorcat Subwoofers 6 2nd March 2005 06:30 AM
Vented box tuning Ilianh Multi-Way 6 16th January 2003 02:42 AM
