Sub enclosure for 10" - Page 3 - diyAudio
Old 18th October 2011, 01:35 AM   #21
carshateme's Avatar
Originally Posted by Brian Steele View Post
No worries
I AM stealing your center piece idea though =PP
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Old 18th October 2011, 01:53 AM   #22
carshateme's Avatar
Here's the design =D
Old 18th October 2011, 10:57 AM   #23
Sorry for delayed reply-did you find the TS paramters for your sub? I may have them at home but organisation isn't my forte so a lot of searching to find them-I've looked online but not found anything...
Old 18th October 2011, 01:06 PM   #24
carshateme's Avatar
Umm ts is total space right? I should have.posted it already if that was it.
Old 18th October 2011, 04:38 PM   #25
Nope, they are the Thiele Small parameters, Thiele and Small were two wonderful guys who took out most of the guess work when modeling enclosures thanks to their work.
Think of them as your chest/arm/neck/waist measurements when you go to a tailor-without them he'd be hard pushed to make a decent suit for you.
Without these I can "design" a box for you-but I cannot see if it's going to sound like a chuffing elephant or whether you're going to run out of excursion on your subs and cook them.
They will have been supplied in the handbook that came with the woofers-please post them up here or let me know and I'll see if I can find a copy (I'm 90% sure i have a copy of these-and 10% sure where it is, so you posting them would save me a load of time hunting!)
Old 18th October 2011, 10:11 PM   #26
carshateme's Avatar
Here's the manual, gotta download it, because I still have no idea what I'm looking for...
Audiobahn ALUM10N Manuals, Support and Troubleshooting
Fs 26.4 Hz
Qts 0.47
Qes 0.51
Qms 4.9
Vas (Liters) 35 Liters
Vas (Cu. Ft.) 1.24 Cu.Ft.
Re 6.0 ohms
Le 2.50 mH
Mmd 158 Grams
Xmax +/- 13 mm
RMS 800 watts
Sd 0.033 M2
Freq. Resp. 20Hz-500Hz
Ported: 1.35
Port size (in) 3 x 7.5
Port Vel. (%) 18.72
-3 dB (Hz) 31.5
Tune freq (Hz) 38
Sub disp .15
Port disp .027
Total vol 1.5
Old 18th October 2011, 11:52 PM   #27
carshateme's Avatar
But what I don't get is do I do the volume after adding the ports or before adding the ports...because if that's the case..my depth is way to big.
Old 19th October 2011, 10:48 AM   #28
Ok, modelled it for you. 1x central port, full height of box, 5.25" wide and 22" deep. You need to use your subsonic filter and set it to 18Hz as a minimum if 12dB an octave or will have to adjust yourself if its an 18/24dB an octave HPF(my software only allows for 12dB an octave) or you'll over excurt below 25-27Hz
Box will tune to 35Hz and F3 will be 31.09Hz-but this is in an open space, it will tune lower in the car and cabin gain will give you plenty of low end boost. Round off the edges on the port to reduce turblunace.
Excuse my sketch-I only have "paint" to play with and I am at work so only a quick sketch!
Old 19th October 2011, 12:00 PM   #29
carshateme's Avatar
Hehe. Sorry for making you do all that work but I was thinking of changing my amp up for a smller one and buying new subs. Finally took it in today. They said one of my voicecoils are gonna blow..so before it does I'm getting rid of them lol. So I'm thinking about getting audiopipe the tx 12s (the blue one) but someone said the la is to high....I can't find any enclosure recommendations for the subs either...but when I do. Can you make some figures for me?
Old 19th October 2011, 12:06 PM   #30
I'd stick with the Alums over the Audiopipe, see your other thread.
How did they discern the VC was "about to go" sounds like BS to me...
Need 10" (12") driver for 30 ltr enclosure. (1.1 cu.ft) Fasen Subwoofers 2 25th March 2010 03:18 PM
Enclosure - 10" Peerless XXLS Guy Incognito Subwoofers 4 23rd November 2007 07:50 AM
10" and 12" sharing the same enclosure prerunnerv6 Multi-Way 3 22nd March 2006 03:30 AM
Enclosure size for Vifa M26WR 10" The Paulinator Multi-Way 7 21st December 2003 05:46 PM
My 2nd Q: 10" subwoofer enclosure kingfootga Subwoofers 4 27th March 2002 10:23 PM
Copyright 1999-2017 diyAudio
