Sub enclosure for 10" - Page 2 - diyAudio
Old 17th October 2011, 07:12 PM   #11
carshateme's Avatar
So the new box layout would look like this:
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Old 17th October 2011, 09:29 PM   #12
look, bro, just go ahead and drop a couple of these back there and you will never look back...
WoofersEtc.com - SA-15 D4 - Sundown Audio 15" 600W Dual 4-Ohm SA Series Subwoofer
I had a brutus bxi 2006 on a pair of these in 6.5 cubes at 39hz..
WoofersEtc.com - 2XL-154D - Powerbass 15" Dual 4-Ohm Subwoofer
..and I have no problem hitting 140's at the kick....there is no substitute for cubic inches.
Old 17th October 2011, 09:37 PM   #13
carshateme's Avatar
1. I hate both speaker brands...if I was going to drop $500 for a sub I would buy a rockford, jl audio, or orion sub.
2. 15" subs DO NOT FIT in my trunk.
3. I love the subs I have now. Just gotta get em in a new box.
4. My amp is 2000watt mono...it'd tear those subs apart.
5. Ty for your input. But I think I'll stick w my audiobahns.
Sounds awesome. Is cheap. Doesn't overheat nor has it blown up.
Old 17th October 2011, 09:59 PM   #14
LOL...ok, bud..I don't buy into "the brand"...I just thought i'd toss you some suggestions based upon the dimensions you gave for your trunk, would fit indeed. Since i have used both on the same amp you use...and it is good you like the audiobahns...somebody has to. I jus figgered you were ready to step up to "theneighborshateme" status.
Old 17th October 2011, 10:42 PM   #15
carshateme's Avatar
Lol. Yeah. I don't have nieghbors....I just got cops to **** off. Cmon baron waiting for those figures.
Old 17th October 2011, 11:23 PM   #16
allright,I feel bad...we all enjoy things that others might like or dislike...it is called DIY...the design you last posted looks pretty decent. I was gonna propose top loading the 15's and porting like you show...something else to keep in mind when using smaller drivers is rear face them to acheive additional loading..rule of thumb is at least width of port = distance from rear of trunk...good luck.
Old 17th October 2011, 11:27 PM   #17
carshateme's Avatar
Yeah my car trunk is only 14.5 " high...
I had subs facing upwards...was a bad idea. Blew off my trunk lock and nearly blew my back window up..thus ill never do that again lol
Old 17th October 2011, 11:46 PM   #18
The center passage needs to have twice the cross-sectional area of one of the side passage.
You can also leave out those things at one end of the center passage and at the ends of the side passages. They're not going to make any difference at bass frequencies. Consider instead adding a center panel down the middle of that center passage and flaring each end of the vents - you can accomplish this by adding a 45 degree section that's at least about 3" long on its shortest side.
Finally, do not permanently mount the side passages until you've had a chance to check Fb - with long, large vents, the box calculators tend to over-estimate vent length to reach a particular Fb.
Old 18th October 2011, 12:17 AM   #19
carshateme's Avatar
... I have no idea what you're talking about. I considerd adding a center piece but then my vents would only be 1" down the.middle. unless you mean taking the angles out of the center and putting a small center piece because I calculated the ports to
be 4" wide and 11.5" tall although I want them to be 7.5" tall. But I'm waiting for baron to get me the numbers cuz he's helped me in the past on these forums...so I know he has experience. Not saying anything bad about you or nothing. Tho the center piece is a great idea if I cut it half way up the.middle. I don't use the port calculators I'm basing this off mu.sub manual which recommends a circle port of 4"x7.5" but I want the.middd ports...more easier for.me.
For baron: my trunk dimensions are 34"x15"x30" but my amp takes off 2" and 28" is touching my tip of my trunk. At the ending of my trunk it curves out and it goes to about 36" . Just giving you an idea of how big my trunk space is.
Old 18th October 2011, 12:45 AM   #20
No worries
www.diysubwoofers.org
Need 10" (12") driver for 30 ltr enclosure. (1.1 cu.ft) Fasen Subwoofers 2 25th March 2010 03:18 PM
Enclosure - 10" Peerless XXLS Guy Incognito Subwoofers 4 23rd November 2007 07:50 AM
10" and 12" sharing the same enclosure prerunnerv6 Multi-Way 3 22nd March 2006 03:30 AM
Enclosure size for Vifa M26WR 10" The Paulinator Multi-Way 7 21st December 2003 05:46 PM
My 2nd Q: 10" subwoofer enclosure kingfootga Subwoofers 4 27th March 2002 10:23 PM
Copyright 1999-2017 diyAudio
