Best enclosure for SQ
Old 16th October 2011, 10:29 PM   #1
TheBassChild is offline TheBassChild  Australia
Default Best enclosure for SQ
Hey guys,
Im doing a home theatre install for one of my mates. Im building him a subwoofer box for 2 10" subwoofer I recently bought as well. Basically I want to know what kind of box is best for Sound Quality. I recently made a T-Line subwoofer box for a single 10" and it was amazing. Unfortuantly the box doesn't work with the home theatre. Maybe there are different types of T-lines that get the same boom but in a different shape. I have around about 1m of length, 40-50cm of width and another 1m of height to kind of play around with.
If you need the specs for the subwoofer here they are:
Nominal Impedance: 8 ohms
Nominal Power: 225W RMS
Maximum Power: 450W PEAK
Frequency Response: 40 - 1000Hz
Sensitivity: 88dB
Qms: 1.011
Qes: 0.473
Qts: 0.322
Vas: 21.76 litres
Fs: 59.82Hz
Overall Diameter: 258mm
Mounting Holes PCD: 245mm
Cutout Hole Diameter: 235mm
Total Depth: 110mm
Thanks for your help
Old 16th October 2011, 10:44 PM   #2
revboden is offline revboden  United States
revboden's Avatar
IB enclosures are the "best" for music, for HT large low tuned BR in my opnion. You will get others that say differently and they will be right as well.
P.s. That's a woofer not a subwoofer ya got there.
Old 17th October 2011, 01:08 AM   #3
What are IB Enclosures? What are BR's?
Looking back on the specs your right. I havent bought them yet, but I was just about to. Thanks for that haha, Ill keep looking. Ill be probably going still with 2 10".
Old 17th October 2011, 01:22 AM   #4
rob g is offline rob g
IB infinite baffle. Closed or sealed unit. Could be used in a roof space or basement.
or could be referring to a closed box subwoofer of a specified volume, these can have tight punchy sound for better transient response.
BR bass radiator or passive radiator or less attractively named drone cone.
This is a drive unit without a full motor system, basically an extra cone that moves out with the back wave of the powered or active driver. This is instead of a port to extend the bass.
Old 17th October 2011, 01:31 AM   #5
Passive radiator does not have a magnet and sometimes does not have the voice coil either. It works of the back pressure from the main drive unit so it is a passive device.
These have to be balanced to work with the main drive unit to extend the bass. typically they will have a larger and heavier (carefully weighted) diaphragm than the main drive unit.
Old 17th October 2011, 01:37 AM   #6
Here is an IB project:
American Basement Solutions: Subwoofer speakers in crawlspace - Infinite Baffle system
A closed box subwoofer can also be refered to as acoustic suspension.
Old 17th October 2011, 03:44 AM   #7
revboden's Avatar
Sorry, i'm used to using abbreviations here. Rob covered Infinite Baffle and Passive Radiators very well. BR can also stand for Bass Reflex or Ported subs which work on the same principle as Passive Radiators.
Acoustic suspension uses the calibrated air spring in the box instead of a stiff suspension to allow more linear restoring force. They are very good but finding drivers built for this design theory are rare.
Best enclosure for SQHide this!Advertise here!
:: sq quadraphonic :: dhengkoel Solid State 33 12th December 2010 02:34 AM
Best Sq sub setup plenk Car Audio 7 21st June 2008 10:19 AM
Best enclosure for SQ? TL? defwing Multi-Way 1 4th February 2008 04:10 PM
Aiming for SQ in a sub ... JinMTVT Subwoofers 31 25th September 2005 09:41 AM
Sq-5 gianis Tubes / Valves 0 11th January 2004 09:12 PM
Copyright ©1999-2017 diyAudio
