Apparently vertical line array woofers work much better with room acoustics, because of how they fill in each others cancellations on all three axis, rather than with the more conventional 2 woofers on the floor. Many high end companies have gone this route. Roger Russel, former head of speaker development at McIntosh seems to be completely sold on it (although his is wideband). I'm thinking maybe 10 five inch drivers with good Xmax per side, sealed box, electronically forced to be acoustically flat from 20HZ - 200HZ with active EQ ahead of the power amp. I also love that they have a very small footprint. I'd be interested in hearing from anyone who's tried this. Photos encouraged.
#2 |
Sign me up! I've been thinking about this for some time
#3 |
I've only used them in stadiums and large theaters but they do work well for semi directional bass. this is a good reference on the topic: http://www.electrovoice.com/sitefile...s%20v03%20.pdf
#4 |
Hold on a moment!!!!
First question: who is trying to solve what problem with a "magic bullet" (while causing other problems using tiny drivers that might be more distressing)? What are their constraints? Let me start by saying that, in my humble opinion, the solution to room modes is to have two very different kinds of subs parked in very different kinds of places in the room.* Can a high-class manufacturer like Macintosh ever suggest something so outlandish while selling their beautiful pairs of matched boxes? Never. So they have to advocate a far less helpful idea like spreading the woofering around high and low, using the conventional symmetrical front positioning. Ben *I also recommend using mixed-bass below around 120 Hz. But that is thread for another day.
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), Klipschorn mixed-bass woofer w/param. EQ plus 1954 AR-1W or giant OB HiFi construction since 1956 |
#5 | |
#6 | |
btw - for frequencies below 120Hz in a typical home size room LF from a line array pretty much act just the same as having a single LF driver - line arrays are not going to solve LF room modes and resonances Last edited by Cokewithlime; 16th October 2011 at 09:30 PM. |
#7 |
I'm gonna agree with cokewithlime, mostly. In a large room (think covered stadium) line arrays work because you are trying to "focus" the bass away from the side walls and get even coverage over a very deep area, in a home the back wall is too close and reflected energy is dominate, distributed bass is the way to go. If you are thinking of using multiple "arrays" or "stacks" the same theory of distributed bass applies you're just distributing it on three axis as opposed to two. I don't think that two arrays in symmetrical placement will solve anything, you're still going to need to put them strategically around the room.
#8 |
Live Sound: Real World Gear: Developments In Cardioid Subwoofers - Pro Sound Web
A good read on y'all's delimmas of low frequency cacellations.... |
#9 |
+2 for cokewithlime and revboden
Actually, my guess is that a line array will provide minimum benefits while at the same time obliging you to use small drivers that aren't near the floor. A poor solution. Line arrays do have advantages but only higher up in the freq compass. Ben
#10 | |
| Open baffle woofer line array concept. | oon_the_kid | Full Range | 14 | 19th October 2011 11:02 AM |
| Sub-woofer for line array. | jerryo | Subwoofers | 8 | 17th October 2011 01:20 PM |
| Line Array question about mid-woofer ! | LowBass | Multi-Way | 3 | 14th September 2011 05:55 AM |
| A few doubts about side woofer line array. | goldyrathore | Planars & Exotics | 1 | 18th September 2009 05:58 PM |
| Mounting tweeters over the woofer in a line array. | GuyPanico | Multi-Way | 8 | 28th June 2007 11:10 PM |
| Page generated in 0.13367 seconds (74.37% PHP - 25.63% MySQL) with 10 queries |
