Stereo sub +2 way
Stereo sub +2 way
Old 15th October 2011, 04:23 AM   #1
1fspd is offline 1fspd  United States
Default Stereo sub +2 way
I'm a speaker "kit" builder. I enjoy woodworking but have neither the skill or motivation to learn crossover and true speaker design. That said I'm very interested in a kit recently offered by Tony Gee, the L'Orfeo. It's a 2 way, ScanSpeak Illuminator 18wu, and a Mundorf AMT in a ported, or a sealed cabinet
I'm planning a sealed cabinet of a somewhat different shape but adhering to the recommended volume, but would like to construct a separate, bass/sub enclosure. I'm a bit of a bass junkie, enjoying everything from dub reggae, to jazz and the blues. In that attached mock up I envision stereo down firing woofers/subs (2 or 4 drivers) in the pictured cabinet (one cabinet, two distinct enclosures).
My primary question is what bass drivers should I consider given my musical tastes, and the 2ways f-3 of 65hz?
The mock up is to scale. Room 13W x 19L x 9h (~2200 cu ft.)
Listen at moderate to high volumes, and with the dub and electronic interest need those lower octaves. Budget is flexible. I've look at Aura, TC sounds, Morel, ScanSpeak 23W and Rythmic but am concerned about asking low frequency drivers to deliver past 100hz.
Also a DEQX express unit (3-way) is slated for crossover and room correction work (lots to learn here, but I love to tinker).
As a speaker "kit" builder I apologize if I'm overlooking some design fundamentals, but none-the-less look forward to your input.
Ryan
Duluth, Minnesota, USA
Old 15th October 2011, 06:43 AM   #2
ODougbo is offline ODougbo  United States
You may have wanted to listed the thread in Multi–Way.
Your profile is similar to mine, i.e. leave the crossover designs the experts and concentrate on cabinet design/fabrication.
You mention bass reflex, but sounds like you are leaning to sealed boxes. My two cents, I have a 3 set of .5 cf bass reflex with a 7” Vifa woofer & Morel tweeter (Madisound crossover). They go low, extremely low way past 40hz, I’ve heard them produce some crazy low notes; sometimes, I don’t even turn on the subs.
Are your sure you want to have down firing woofers? I’d be worried that the bass would be muddy vs. speakers pointed at listener.
Old 15th October 2011, 07:22 AM   #3
chris661 is offline chris661  United Kingdom
chris661's Avatar
Down firing woofers have been used often enough, with no complaints of muddiness. A "muddy" bass sound would imply some missing harmonics of, say, a bass guitar. That'd probably be down to sub-optimal integration with the mids.
Remembering that a down-firing subwoofer is as omnidirectional as any other direct radiating subwoofer (in their correct operating range), I can't see there being a problem.
It sounds to me like you'd want to go to at least 30Hz in terms of extension. To find out exactly how low you want to go, get hold of Foobar2000 with the additional crossover. Try messing around with highpass filters (through a decent pair of headphones) to find what low frequency rolloff is acceptable to you: if you add a crossover at 30Hz and find you're missing some content, then, ideally, you'd have a subwoofer that'll go lower than 30Hz. Of course, the desire for extension has to be balanced against cabinet size amongst other things.
Chris
Old 15th October 2011, 10:43 AM   #4
You’ll want to check out this site ~ http://www.zaphaudio.com/index.html
I’m getting ready to build the ZA-SR71s, (reasonably priced kit) for a co-worker.
Old 17th October 2011, 07:30 PM   #5
jacubus is offline jacubus  United States
jacubus's Avatar
Thank you for that link ODougbo.
Laughing up the wrong tree
Old 17th October 2011, 08:10 PM   #6
I ordered a SZ71 kit from Madisound today; the advertisement sure reads nice. I’ll keep you updated…..
BTW, there are complete fabrication plans if you follow the links.
Old 28th October 2011, 03:46 PM   #7
Default SR71 Build
Pretty cool, easy to follow plans. I've only had them running for a few hours, they do play loud and lots of detail.
If the budget wasn't so tight, I would have upgraded the inductors to Perfect Lay air coil ~ 14 gauge.
Nice Speakers!
Stereo sub +2 wayHide this!Advertise here!
sony SVO-1630 hi-fi stereo vhs stereo recording/playback problem neazoi Analogue Source 1 7th October 2011 07:36 AM
Novice stereo subs project with stereo amp. PJeff Subwoofers 70 28th August 2011 06:48 PM
Stereo in/multiple Stereo outs Circuit MartinByrne Everything Else 3 7th May 2009 01:11 AM
2 Stereo in's, 2 Stereo out's, USB DAC djd4n Digital Source 13 28th August 2004 02:23 PM
How do I wire stereo headphones on a stereo tv? hike1 Everything Else 2 10th September 2001 02:22 AM
Copyright ©1999-2017 diyAudio
