Question: Is there any practical reason to prevent one from having the majority of a pvc port OUTSIDE of the enclosure( meaning maybe 7" inside, and the rest outside) beside cosmetics?
Background: I acquired two 2.6cuft sealed subwoofer Cabinet from a guy from work and am considering converting them to ported boxes for my "party room". They are actually ceramic chimney flu liners surrounded by and bonded to two sheets of 3/4 in MDF on each side, with the baffle side and "plate amp" side being just braced mdf (no flu liner They are massive for a sealed 12" woofer box. He originally used them with a pair of Dayton titanic MkIIs back in their heyday, with a final Q of 0.50000 I have no real desire to use them as a sealed box, I have no subwoofers that would work well in that size enclosure, nor do I desire to buy them. Goal: Use a pair of subs I have in my basement, design a ported enclosure with V<= 2.6cuft; if the port is external, as low tuned as possible with external tubing, maximizing response to 19Hz (+0-3db to 20Hz), port velocity <19m/s at max power, never reaching the excursion limit of the driver (23mm lin one way xmax). Note: If I could cut through flu liner I would just use some new css PRs, but alas I cannot! |
#2 |
Other than looking odd, no reason you can't extend the port outside the box. 2.6cu/ft is fine for a decent twelve. I wouldn't tune them so low. Hoffman's iron law. I'd use bigger drivers and boxes for better efficiency for those low frequencies. Human hearing rolls off quite a bit, so you need more SPL to hear those low frequencies with any real impact. Tuning so low also squanders the efficiency of the woofers for higher bass 30hz on up where it has real impact. I'd tune such boxes in the mid 30Hz range, but no lower than 30Hz, If for HT, build bigger boxes.
#3 |
None, a port can be inside, outside, or any proportion thereof.
High current requirement is the bane of high fidelity |
#4 |
Space considerations in the room prevent anything larger than this pair of boxes, unfortunately. I would prefer to make a giant LLT style pair with a different driver but right now, 2 subs I already have and a pair of sealed boxes for $35/pair was all I could swing to this project.
So many projects, so little time. |
#5 |
considering a driver with the excursion you quote, you're going to have a tough time tuning down that low in a box that small. if you don't have the TS specs for the drivers, i'd start with a 6" pipe 34" long and see how it goes, should tune to about 28Hz.
#6 |
Fs 25.21 Hz
Qms 4.748 Vas 41.71 L Cms 121.9 umN Mms 326.8 g Rms 10.91 mohms Xmax 23 mm Xmec 32 mm Dia 25 cm Sd 491 sq. cm. Vd 1.129 L Qes 0.383 Re 3.6 ohms Le 1.319 mH Z 4 ohms BL 22.07 NA Tm Pe 1000w (up to) Qts 0.354 no 0.169 SPL 84.3 1W1m SPL 87.89 2.8V1m |
#7 |
A quick sim puts me at 17m/s port velocity @ 25Hz @ 600watts
2.4 cuft box with 5x47.6in vent @21hz |
#8 |
5"x47.6" vent has pipe resonance of 147Hz. unless you are going to cross very low that's bad. I try to stay below 34" for vent lengths so they keep resonance above ~200Hz.
| Enclosure Change Horn/Ported/Sealed/TL-Sub, For Existing Altec Lansing 2.1 System | ankithmistry | Full Range | 9 | 25th May 2011 07:42 PM |
| what are some sealed and ported box sizes you can suggest for this speaker ? | zuki | Subwoofers | 17 | 8th March 2007 05:51 PM |
| hifonics atlas 12's sealed or ported box | bmwbooms | Subwoofers | 1 | 9th October 2005 04:57 AM |
| what size sealed or ported box can this woofer use ? | zuki | Multi-Way | 2 | 23rd November 2004 02:20 AM |
| opinions of T/L box V ported OR sealed | busterno1 | Multi-Way | 13 | 28th November 2003 08:20 AM |
| Page generated in 0.13517 seconds (70.24% PHP - 29.76% MySQL) with 11 queries |
