Old 3rd October 2011, 04:02 PM   #1
rvrazvan's Avatar
Default Dual action Tapped Horn (New ideea..maybe)
I want to explore this topology but i will need some help in order to aproximate an result.
the picture say's it all.
Old 3rd October 2011, 04:29 PM   #2
ßart West-VL.'s Avatar
What would be the advantage over one TH with the same dimensions with two drivers as your dual TH ?
Bart
Old 3rd October 2011, 04:56 PM   #3
Looks like it would work fine. whats ur math for tuning and so on say.
Old 3rd October 2011, 05:41 PM   #4
That's an interesting allignment.
if you reverse one driver the "average driver" is a flat piston.
A downside for PA mostly would be that if one driver stops you effectively get two off-set horns.
An upside could be that you can use different sized drivers (see were that takes you).
Makes me wonder:
You could use two drivers in a single tapped horn and have the other side of the diaphragm load something else, say a closed box (or a reflex) to change compliance / excursion. Differerent enclosures could mean you could tweak the ratio of the throat : mouth level/ contribution?
Thinking out loud, it would diminish the tapped horn double Sd-effect but would result in endless days of experimenting, possibly finding the next step.
Best regards Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 3rd October 2011, 05:44 PM   #5
rvrazvan's Avatar
One advantage of this is that you can have a ...straight tapped horn if you like.
That is not possible with a normal tapped horn.
The math for this....is way out of my league. Time to learn akabak !
Old 3rd October 2011, 06:01 PM   #6
Yea I hear you. I can build ported cabs all day but thats about it. well and sealed. lol
Old 3rd October 2011, 09:51 PM   #7
Djim is offline Djim  Netherlands
Isn't that a downsite that counts for almost all PA subs with multiple drivers and combined spaces?!
Old 3rd October 2011, 09:59 PM   #8
rvrazvan's Avatar
SO.... back to the problem. any ideea how i can model this?
Old 4th October 2011, 02:57 AM   #9
I think you'd see more of an advantage from a push pull alignment of the same volume...
Old 4th October 2011, 07:54 AM   #10
You can do it in Hornresp.
Look at your "unfolded" diagram. Cut it along the diagonal partition. Each half looks just like the schematic diagram of a tapped horn in Hornresp, right?
Now double its width (cross sectional area) and use 2 drivers.
In other words, a "conventional" tapped horn with two drivers and the same dimensions will perform identically (at least in simulation) to your design.
Dual 8" tapped horn = TH-SPUD geitmans Subwoofers 119 1st January 2012 08:14 PM
mcm 8" dual tapped horn plan soundhead Subwoofers 13 27th May 2010 03:28 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Page generated in 0.12197 seconds (62.75% PHP - 37.25% MySQL) with 11 queries
