Old 3rd October 2011, 03:01 AM   #1
Default Truck Subwoofer,
So i'm going to build a sub box for my dads truck, but a center console. I was coming here to get some advice on what to do with it, i would like to try and make it a solid low playing box, but i'm not sure how to design a ported box, unless sealed is the better scenario for this sub, unfortunately is a pretty new brand, that doesnt hardly release a lot of information on their stuff. I got these 2 10s for free, and decided to put them to use.
but here are the parameters provided
Fs 28
Qts .75
Qms 3.4
VAS 39 Liters
Xmax .3 inches
Re 2
Pe 1500
Q @ Fs .96 ?usable parameter?
Sens 82 Db
and i have 2, and im going to build a center console in a 95 ford Crewcab, so i have quite a bit of room for a box, any help would be really appreciated
Thanks,
Cody
Old 3rd October 2011, 04:49 AM   #2
krips is offline krips  Canada
Sealed or ib are the way to go for those. Low xmax though.
Old 3rd October 2011, 02:38 PM   #3
what is ib? and does low xmax make a big issue?
Old 3rd October 2011, 06:19 PM   #4
revboden's Avatar
IB = infinite baffle
go sealed ~2ft^3 total for both drivers, i'm guessing here.
there is no way that drivers Pe is 1500. more likely ~80 those parameters are very suspect. you'll have to go old-school and experiment.
Old 3rd October 2011, 08:23 PM   #5
unfortunately thats the only option i cant fulfill. he has done walk through's himself, but its kinda our last work vehicle, and the bed will be used, and i highly doubt the 1500 as well, i've been enough around stereos to weed out fantasy from facts. do you think my lower end output will be sufficient in a sealed box? i know with tuning a ported box you can squeeze Db out of it at certain frequencies, and if that requires too big a box, i could do it isobaric to reduce box volume
Old 4th October 2011, 02:56 AM   #6
What is the actual size of the space(centre console) ,perhaps a tapped horn could fit in there?
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 5th October 2011, 11:15 PM   #7
well does anyone by chance know the size of the front middle seat in a '95 F-350? i will go measure tonight, but if by chance anyone knows and can supply us the info between now and then that would be excellent
Old 5th October 2011, 11:29 PM   #8
I remember JL Audio putting out sealed boxes for the larger trucks that looked like arm rests in the center of a bench seat. The woofer fired down with decent results. Any room for 10"ers in your kick panel area?
Old 5th October 2011, 11:31 PM   #9
Unfortunately not, its a 5 spd, and no room whatsoever on the drivers side in the kick panel
Old 6th October 2011, 09:36 PM   #10
chris661's Avatar
With such a high Qts, I'd consider sealed. A ported box (even isobrarik) would end up too big, and getting a flat response would be very difficult.
With regards to the limited Xmax, that'll just limit how loud it can go before distortion comes in. Kinda - it's complicated, but running the drivers past Xmax isn't considered a good idea if sound quality is on the menu.
I'd go for a box as big as possible, make sure it's well braced, then consider adding stuffing (I believe it's polyfill over at your side of the pond).
Chris
Unique sub for truck. pikipupiba Subwoofers 20 24th July 2011 04:44 PM
Truck underseat sub x. onasis Subwoofers 2 23rd January 2010 02:48 AM
truck sub box d3imlay Subwoofers 2 17th June 2008 04:56 AM
What Box In My Truck? 26sonmytruck Subwoofers 1 15th May 2006 03:08 PM
Page generated in 0.14588 seconds (63.22% PHP - 36.78% MySQL) with 10 queries
