4x15 tapped horn ?
4x15 tapped horn ?
Old 3rd October 2011, 02:48 PM   #11
60ndown is offline 60ndown  United States
musical burps?
Old 3rd October 2011, 03:36 PM   #12
KRhirschkorn is offline KRhirschkorn  United States
6 second burp of 58-68 Hz
Old 3rd October 2011, 03:57 PM   #13
camaudio is offline camaudio  United States
are these dual, quad? what impedence?
Old 3rd October 2011, 04:47 PM   #14
quad 2 ohm.
Old 3rd October 2011, 06:58 PM   #15
chris661 is offline chris661  United Kingdom
chris661's Avatar
I would like to see a picture of the motor assembly that will stand up to 2.5kW continuous, 10kW peak.
Please.
Old 3rd October 2011, 07:07 PM   #16
Ill see if i cant get pics of 2 dif brands that will and do the ones i have are the same brand that at one point years ago held a world record of close to 180 Db.
Old 3rd October 2011, 07:43 PM   #17
OK heres the pic you asked for this is the 4 subs i have now..
Heres the other subs that handle the same amount of power.
Those are memphis MOJO's they come with 4 voice coils
Old 3rd October 2011, 07:48 PM   #18
jbell is offline jbell  United States
yea I just gotta see these drivers too....
they sound plain nuts.
I ran 0.5pi for 4 of these and 2.5kw and it's still within xmax at 40hz in an ss15.
edit:
I see the pic... that sucka won't fit in the ss15 cab....
Old 3rd October 2011, 07:50 PM   #19
The coils after 2 years worth of being railed on hard.
And with the mag bolted up..
Old 3rd October 2011, 08:09 PM   #20
Ok guys sorry for all the post's. the MOJO's are the ones I ran in my van and have still. They are the ones with the spec's that I posted. And the ones I want to put in a Tapped Horn. and feed each one 1Kw. I'll try and find the Specs for the Holee **** 15 But to be honest they need more power then my MOJO's did.
OK here's the specs on the hole S 15
Mechanical Specifications
Weight 112 lbs.
Rear Mounting Clearance 14.25”
Woofer Magnet Dim. (dia. x ht. In mm) 275x19x4
Voice Coil Diameter 76mm (3”)
Voice Coil Winding Layers 8 (two 4 layer)
Measured T/S Parameters
Nominal Impedance (Ohms), coils in series 2
Revc (Ohms) 2.15
Sd (cone area in sq. meters) 0.0894
Bl (motor strength in Tesla Meters) 17.2
Vas (in liters) 124.2
Cms (micrometers per Newton) 129.5
Mms (grams) 398.5
Fs (Hz) 22.2
Qms 5.79
Qes 0.40
Qts 0.38
Power and Excursion Data
Sensitivity (2.83V/1M in dB) 87.1
Continuous Power Handling (watts RMS)10,000
Peak Power Handling (watts) 25,000
Xmax ([coil length – gap height]/2 in mm) 44.5
4x15 tapped horn ?Hide this!Advertise here!
Help with a tapped horn. mike james 533 Subwoofers 33 4th January 2013 11:25 AM
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
