Slot Port(s) the easy way
Old 30th September 2011, 10:16 AM   #1
ODougbo is offline ODougbo  United States
Default Slot Port(s) the easy way
Found this pic and thought some might find this interesting. I’ve built peaty of bass reflex speakers with PVC/Cardboard tubes and came up with a faster/ easier way to tune up a speaker. As some have found out, it’s not easy to pull a PVC tube out a speaker (cardboard is even worse).
The ploy is pretty simple, semi build the box, basically in three parts. (1) side with “rips” top/bottom/back, glued on (2) baffle board with speaker(s) and “L” (3) the 2nd side panel.
It is a dry fit process, it is import to have all the “rips” exactly the same, or air will leak all over the place. Remember to leave plenty of extra material at the top of the baffle board, so it can be slid up and down. Of course sliding the baffle board will change the slot port area/volume.
Once you have it “assembled” hook up to a resistor load and watch the peaks on a volt meter and listen to the bass. You can cut or add to the slot port if needed.
Worried about air leaks anyway, tape them up.
Pics – two different projects, same idea.
Old 30th September 2011, 10:34 PM   #2
revboden is offline revboden  United States
revboden's Avatar
Do you know that when a slot port aspect ratio gets higher than 1:4 (h:w) that the port starts to detune i.e. the tuning goes up instead of down (~1:8) until it reaches aperiodic friction coefficient (1:14 ) where where the boundary layer takes up the entire volume of the slot at about 90db.
With a high ratio slot port the tuning of the box is dependent on drive level, ie the higher the spl the higher the box tuning shifts.
There are better ways to design a slot port.
Old 2nd October 2011, 10:54 AM   #3
Thanks for the info on the 1 to 4 ratio. However, I do think a slot ports work better than round tube; a recommendation based on many speaker projects. The wife tells folks, “he builds 19 pairs of speakers, and keeps one pair”.
I do have two (2) of the isobaric “cube” subwoofers (pic on right) in the HT and getting awesome bass; like having my own private orchestra. There may be as simply answer, e.g. the slot is lower close to the floor.
Speaker(s): http://www.mcmelectronics.com/product/55-2421 The height of port is slightly les than 3/4” x 13 1/2” deep, 10”wide.
Old 2nd October 2011, 11:09 PM   #4
revboden's Avatar
What you have there is an semi-aperiodic woofer. close to a 'Fonken'. P-10 has good info on them Meet the Fonkens
Old 3rd October 2011, 06:26 PM   #5
Thanks for the info, I just asked that question on another thread. All I need is a center brace.
I do think the MCM project is a little out of the ordinary, low cost, fairly easy to build and a solid sounding sub. I have other 10s, 12s and always come back to the MCM Isobaric.
Old 3rd October 2011, 07:36 PM   #6
carshateme is offline carshateme  United States
carshateme's Avatar
Not part of the topic, BUT DAMN! I wish I had those clamps when I was building my box...THOSE THINGS ARE HUGE!
1995 Buick Skylark Custom: Hifonics HIF2000D amp Big 3 Upgrade 1/0 gauge wire 3 10" ALUM10N Audiobahns XS Power XP2000 battery Sony CDX-GT43IPW head unit 12k Kensun headlights L.E.D back Kensun lights Street Glow blue neon light interior
Old 3rd October 2011, 09:16 PM   #7
Darn clamps………they went up up up $$$
I won’t be buying more anytime soon. Yes the point is, you can dry fit speakers (and side the baffle board to tune).
Old 4th October 2011, 05:36 PM   #8
dirkwright is offline dirkwright  United States
dirkwright's Avatar
I won’t be buying more anytime soon. Yes the point is, you can dry fit speakers (and side the baffle board to tune).[/I]
The smaller bar clamps in the photo are about $15 each at the HD. For larger clamps, I use pipe style "pony" clamps.
Slot Port(s) the easy wayHide this!Advertise here!
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 03:38 PM
slot port Q audiobahnkid592 Car Audio 5 11th January 2009 11:13 PM
Folded Slot Port diesel_88 Subwoofers 4 5th June 2008 01:35 AM
Slot Port in Corner? Alero Subwoofers 1 21st November 2005 12:12 AM
Slot port help Javaman Subwoofers 6 9th March 2002 08:53 PM
Copyright ©1999-2017 diyAudio
